wet passenger seat carpet?! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-23-2006, 10:09 PM   #1 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
3rd Generation wet passenger seat carpet?!
ok when it rains, the whole passenger side carpet is SOAKED.. meaning if i pushed my finger down on it, water will show.. does anyone have this problem or a solution to it? i cant seem to find the origin..
MrSo0h0o is offline   Reply With Quote
Old 01-23-2006, 10:15 PM   #2 (permalink)
View Grayguy's Photo Gallery
Is it isolated to teh front or the back? My car's rear passenger side window leaks like a sive. IT seems that the trim that meets the glass on the out side, doesn't seal it anymore. My temporary fix was to shove a towel inside the door (made easier by the fact there are no door panels/ interior back there...) But I will eventaully have to order a new seal for the dealer. You probably have a similar problem.
Grayguy is offline   Reply With Quote
Old 01-23-2006, 10:50 PM   #3 (permalink)
Gameroom cash: $926800
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Check where the wireing goes from the door to the car body, and make sure the rubber is securely in place on the body.
5 Lug Corolla WHAT?
Old 01-24-2006, 03:38 AM   #4 (permalink)
PRG
View PRG's Photo Gallery
Does yours happen to have a sunroof?
Mine does and the drain holes (yep, the sunroof has drainholes that run down the two front pillars) were clogged with leaves and tree debris and caused the water to pour into the front floor area. A good blast from an air compressor will clean out those drains.
Otherwise, aside from checking your firewall, check the area between the front fenders and the doors, tons of leaves and pinestraw tend to get clogged in there.
PRG is offline   Reply With Quote
Wet Carpet from Water Leak & Toyota Service TacoSport05 2nd Generation (2005+) 12 01-10-2006 12:23 AM
Passenger Seat Bar for Amp shamoon 2nd Generation (2005+) 12 11-06-2005 01:09 PM
'05 Passenger Seat Belt Warning Buzzer goaway113 5th & 6th Generation (2002-2006 & 2007-2011) 12 03-29-2005 11:12 AM
ratling noise coming from passenger seat Newbie Hardcore Tech and Competition 2 12-14-2002 11:19 AM
ratling noise coming from passenger seat Newbie General Discussion 1 12-13-2002 10:34 AM
