Originally Posted by mystickid
Has anyone swapped in, an LED Festoon Domelight/maplight instead of the OEM Incandescent Festoon bulb.
I read somewhere that the LED Festoon Bulbs don't light up as much area as the LED ones or aren't bight enough.
If you swapped an LED Domelight in, how is your experience with the New LED dome/maplight???
Pictures would say alot!
I got em! I got the map and the dome light. the dome is white, 9 led lights and uhm the map...i forgot. I dont have pictures right now, and pictures dont help too much as all cameras adjust to different lightings.
The map light white is really white, while the dome light seems to give off a light bluish tint. No the map light isnt as bright as stock but it looks awesome. you may need to squish the clips a little to keep the contacts on the bulb. The dome light does a fairly good job of lighting things, but i wish it were whiter.
I also have a 5led trunk light which is for sure brighter than the oem bulbs.
Overall...its more for looks, minus the trunk one.
