3vz - 2vz differences? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-24-2006, 07:58 PM   #1 (permalink)
Just trying to turbo
theman33b's Avatar
View theman33b's Photo Gallery
Question 3vz - 2vz differences?
Hey guys i have one big question for you, I have a 2vz and i hear that the 3vz is not much different. I would like to know what are the differences besides one is 3.0 liter and one is 2.5 liter. I have found some parts for the 3vz and i was wondering if they are interchangable for example: heads, cams, throttle body, etc. are most parts interchangable? which ones aren't? thanks for your help
theman33b is offline   Reply With Quote
Old 01-24-2006, 11:27 PM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
no, no, if you adapt it to fit, etc, no, many, no problem.
terrastrife is offline   Reply With Quote
Old 01-25-2006, 12:17 AM   #3 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Nothing is interchagable engine wise..without machining. TB won't fit as the intake size/design is different, so ud need an adaptor plate..but even then, the TPS and IAC might be different,... heads won't work as the coolant passages etc are all different...cams won't just bolt right in, ud need machining and some custom bits for it to work properly..and as far the ECU can handle all of this, no idea.
JetspeedCamry is offline   Reply With Quote
Old 01-25-2006, 02:51 PM   #4 (permalink)
MCH Engineer in training
Location: A-town, Doylestown, & Northampton, PA; Morgantown, WV (WVU COE)
View ag6286's Photo Gallery
idealy they are similar, in reality, spec wise, very very different, my suggestion...dont attempt interchanging any engine related parts,. they will only cause you problems
ag6286 is offline   Reply With Quote
3s, 2vz, 3vz free power, OH MY! Toysrme Camry & Solara Lounge 152 05-06-2012 02:17 PM
2VZ to 3VZ swap? and other q's lexusmech Camry & Solara Lounge 2 12-21-2004 03:51 PM
what are the differences between twin entry and single entry da_horse Hardcore Tech and Competition 9 01-23-2004 01:43 AM
