Tire Sealant & Inflator Kit - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-25-2006, 10:23 AM   #1 (permalink)
View joandjo's Photo Gallery
I have minor tire pressure leak. I put 32psi. In two weeks, one goes to 28psi while the rest remain at 32psi. I tried to find the leak with spraying soapy water - no luck.
So I'm planning to use the inflator kit (with sealant). Will it be bad idea? Any negative side such as sticky rim or clogging valve stem...
1992 Toyota Camry LE, 3vz-fe, 254K mi, still going strong...
joandjo is offline   Reply With Quote
Old 01-25-2006, 02:20 PM   #2 (permalink)
Moving Forward
View Cyorke's Photo Gallery
yes it is not recommended to use fix a flat for extended periods of time. I used to work in a tire shop when I got out of school and we had a girl come in to get ehr tires balanced. I was the one doing it and they would never balance out right. I finally asked her if she had put anything in the tires because you could hear liquid in them. She said her dad had told her to put fix a flat in all of her tires so they wouldnt go flat. The only problem is that is is all liquid and will cause very bad vibrations.
You should take it to a tire shop and have them take a look at it and see if they can find the problem. It could be a bad valve stem, or even a bad wheel.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 01-25-2006, 03:07 PM   #3 (permalink)
2004 Camry LE
somick's Avatar
Gameroom cash: $102015
View somick's Photo Gallery
Cyorke!!!!!
That is a perfect explanation!
I have always heard that the repaimen simply do not want to get their hands dirty.
Thans,
Sam
2004 Toyota Camry LE
1999 Honda Accord LX
1992 Subaru Loyale
2010 Subaru Forester
somick is offline   Reply With Quote
Old 01-25-2006, 04:16 PM   #4 (permalink)
Cyorke, thanks for your advice!!!
Old 01-25-2006, 06:10 PM   #5 (permalink)
Dave's
Gameroom cash: $122050
View Dave's's Photo Gallery
Some tire sealants are highly flammable also so the poor SOB sucking on a cig while removing the tire from the rim-whoosh! (Or anything which could ignite it)
Dave's is offline   Reply With Quote
Tires Feedback: Everyone please contribute. EKam Hardcore Tech and Competition 98 12-19-2006 02:05 AM
new owner problems dack41 2nd Generation (2005+) 17 10-04-2006 10:53 PM
Best Tire Sealant abovethelaw General Discussion 7 04-04-2005 01:31 PM
Pro Comp Tire Seperation Causes Crash Z71sc Feedback: Buyers, Sellers, and Vendors 0 10-19-2004 05:01 PM
