Found most info....
Thank you for the information....
I found this searching...
CAMRY V6
ENGINE
3.0 liter 6-cylinder vee-type four cam
24-valve multi-point EFI, aluminum block
with aluminum alloy heads
Bore & stroke 3.44 x 3.27 in
Displacement 3.0L/2995cc
Compression ratio 10.5:1
Valve train Twin-cam, 4-valve/cyl
HP (SAE Net) 188 HP @ 5200 RPM
Torque 203 lb ft @ 4400 RPM
Ignition system Electronic
Fuel system Multi-point EFI
Recommended fuel 91 Octane
Still looking for injector ohms, fuel rail pressure and stock fuel pump lph.
Thank you!
SCDTRD
1994 Toyota Camry V6 XLE  I LOVE it!
And the journey continues........
