tranny shifting hard - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-25-2006, 09:35 PM   #1 (permalink)
Ford Powered
View initial-T's Photo Gallery
4th Generation tranny shifting hard
so my mom's camry has problems shifting. it upshifts and downshifts hard occasionally.
2001 camry ce. 90k miles.
never had tranny flushed. could that be the problem?
or what are other possibilities?
- 1999 Ford Mustang LX 5-spd
- 1993 Toyota Camry Wagon LE SOLD
initial-T is offline   Reply With Quote
Old 01-25-2006, 10:03 PM   #2 (permalink)
View 97&02camryleI4's Photo Gallery
I'd first check the ATF level and condition, then do a drain and fill. Also, drain and fill the differential while you're at it. I'd stay away from a flush if there never has been a tranny service done on it.
97&02camryleI4 is offline   Reply With Quote
Old 01-25-2006, 10:10 PM   #3 (permalink)
Ford Powered
so whats the difference between a flush and drain/fill.
Old 01-25-2006, 10:21 PM   #4 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Drain and refill changes about half the fluid. The fluid in the torque converter doesn't come out. Flush changes all the fluid in the system including that in the torque converter.
2007 Camry 2.4L 5M
Old 01-26-2006, 12:57 PM   #5 (permalink)
92 Camry 3VZFE
toyoonly's Avatar
View toyoonly's Photo Gallery
Why stay away from a flush? Why does it matter if hes had a tranny service done? (not disagreeing, just questioning!)
toyoonly is offline   Reply With Quote
Old 01-26-2006, 01:35 PM   #6 (permalink)
Reason why not a flush is because his tranny has 90k (which isn't a lot at all) but since he's said he's never done any work on the tranny (drain and refill at approx. 30k then at 60k), there might be accumulated debris or particles that have sealed itself against any leaks in the tranny. If doing a flush, the flush might cause these particles to be disloged into the transmission, thus causing a leak from where there was once a seal formed by the particles. I hope it makes sense but someone else can probably explain it better. It's some advice that I've learned and pass on when I hear members bring this question up when doing a transmission service.
Old 01-26-2006, 11:06 PM   #7 (permalink)
Ford Powered
hmm ill look into doin this in the morning. its such a pain crawling under her car lol.
90 Camry tranny replacement Montanahelp 1st & 2nd Generation (1983–1986 & 1987-1991) 3 12-23-2004 09:51 PM
Life sucks! Front wheels locked up! Tranny? es250nut Camry & Solara Lounge 4 10-08-2004 12:27 AM
My tranny shift hard. Plz Help!! 89_3SFE Celica Forum 3 09-24-2004 04:50 PM
Manual Tranny swap for ES300 using V6 Camry Tranny??? JHolland Hardcore Tech and Competition 12 07-17-2003 08:26 AM
