cluster swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-26-2006, 03:34 PM   #1 (permalink)
Andre
View 88Cam's Photo Gallery
cluster swap
my 88 Camry has the cluster without the tach. and i found some clusters on ebay that has the tach. so i was wondering if its a direct swap as far as the wiring harnesses go. and how would i go buy hooking up the tach. any help would be appreciated.
88Cam is offline   Reply With Quote
Old 03-22-2006, 09:33 AM   #2 (permalink)
Toyota Hemi
camryfour's Avatar
View camryfour's Photo Gallery
Yeah I have heard that it is a direct swap wiring and all. I know they all have pretty much the same harness. I suppose you are talking abut the 4 cyl. Check this out: http://toyotanation.com/forum/t99338.html they have a pic there for the place to connect the tach.
camryfour is offline   Reply With Quote
Old 03-22-2006, 11:58 AM   #3 (permalink)
Tom 2000's Avatar
Gameroom cash: $201300
View Tom 2000's Photo Gallery
Just make sure you get the cluster from a car with the same engine (4-cyl to 4-cyl, V6 to V6). The V6 tach won't read correctly on a 4-cyl and vice versa.
The 4-cyl redlines at 6000 RPM. V6 redlines at 6700 RPM. The speedos on the V6 cars go up a little higher also (to 150 MPH).
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
Cluster Swap 01 corolla questions Rambo500 Archived Corolla threads 12 07-20-2006 10:07 PM
Cluster swap??? Darknights Yaris, Vitz and Echo Forum 2 05-24-2005 04:32 PM
Cluster SwaP???? KaMLuNg Archived Corolla threads 6 11-14-2003 11:12 AM
Gauge Cluster Swap cheeba Camry & Solara Lounge 3 10-24-2003 03:28 PM
