Trunk Locked @&*(! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-27-2006, 01:06 PM   #1 (permalink)
97 Camry
View Davee's Photo Gallery
Trunk Locked @&*(!
Bloody cable would not open trunk & key was never provided.-- Is it supposed to be the same as door key?
Anyway removed the pull crank & tried cable direct -- no, go
So went in through trunk & released . Now working fine -- not frozen no jams so what was happening?
Now will look for a replacement trunk lock & key -- Anyone parting out?
1997 Camry LE
Davee is offline   Reply With Quote
Old 01-27-2006, 01:12 PM   #2 (permalink)
97 Camry
Differnet keys
Ah Search & yee shall find-- I never new about the valet key which is not supposed to open trunk . There is hope yet!
Old 01-27-2006, 01:13 PM   #3 (permalink)
The Other White Meat
terrastrife's Avatar
the 'master' key opens, 'valet' key wont. if your key cant lock/unlock your glovebox, better talk to whoever you got the car from.
terrastrife is offline   Reply With Quote
Old 01-27-2006, 02:36 PM   #4 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
The difference in the valet key is that the tip is wider for 3mm than your normal one.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 01-27-2006, 05:01 PM   #5 (permalink)
Dave's
Gameroom cash: $122050
View Dave's's Photo Gallery
It may make a difference which way you turn the key to lock the trunk too. One direction allows the trunk to open with the inside release and the other does not. At least on my '92 and '01. (valet position)
Dave's is offline   Reply With Quote
Old 01-27-2006, 05:27 PM   #6 (permalink)
Gameroom cash: $926800
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Bring your Registration for the car to the Dealer Parts counter. They will make a new MASTER Key for ~$10. Note, Car must be registered in YOUR name to do it.
Also, my Nana's '95 Rolla JUST had that problem. Key would not work in the trunk. I went to a parts store, bought some graphite, sprayed it in, jiggled like hell for a wil, and it works as new now.
5 Lug Corolla WHAT?
Old 01-27-2006, 06:46 PM   #7 (permalink)
mickeyd's Avatar
View mickeyd's Photo Gallery
only the master key will open the trunk when turned to the right, if you turn it to the left, and then remove it, leaving the slot in the horizantal position,it diables the inside release.
mickeyd is offline   Reply With Quote
Old 01-27-2006, 08:20 PM   #8 (permalink)
The Greatest
View CamNub's Photo Gallery
You could also crawl in through the back seat and pull that lever. It glows in the dark.
I honestly think those levers were put there so people can't shove people in the trunk like the old mafia movies...
CamNub is offline   Reply With Quote
Old 01-27-2006, 09:39 PM   #9 (permalink)
I hope that's a joke..........That IS why they were put there.....
5 Lug Corolla WHAT?
Old 01-27-2006, 10:06 PM   #10 (permalink)
Dave's
Actually I thought the main reason was to prevent kids from getting accidently locked in and dying. The mafia aspect was just a bonus.
Old 01-27-2006, 10:14 PM   #11 (permalink)
Thats the other main reason also. For kids, and also for carjackings. Many people during a carjacking were put in the trunk with no way to get out. This prevents both of those. It is a REALLY good idea they did it.
5 Lug Corolla WHAT?
Old 01-28-2006, 01:18 AM   #12 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
3rd Generation Tell Me more about the Master....
Slight change of subject but same problem.....
Mine is a used cammy: My keys will only unlock the drivers door. It will not lock it or lock/unlock the passenger door. It does work in the trunk.
Any thoughts? I did lube and jiggle and can get the drivers side to lock once in a while with the right jiggle action. And if the planets align properly the passenger door may let you in on occasion but never if its raining. It makes it hard to be a gentlemen and I'm afraid if she has the keys, she might just dust my a$s and leave me. So we do need a solution here!
Is it the key or the door locks?
Thanks,
Randy
73sport is offline   Reply With Quote
Old 01-28-2006, 01:32 AM   #13 (permalink)
^ What kind of lube did you use? You need to use graphite. It's dry, so it does not evaporate like WD-40/others. It has solved every lock issue I've had in any car. Less then $2 a tube also.
5 Lug Corolla WHAT?
Old 01-28-2006, 10:51 AM   #14 (permalink)
V8'sRGone
73sport's Avatar
3rd Generation
^ Its called "Tri Flow Super Lubricant" with teflon. I got it at t bike shop its for cables and chains and is not supposed to run off in water.
It made the locks way better than they were but i still can't turn them like they should unless the jiggle method is used.
So tell me more about the valet keys. Niether of the keys i have are original toyo, perhaps I should start their?
Tell me more about: "The difference in the valet key is that the tip is wider for 3mm than your normal one." cause for i all I know I don't have masters????
Oh - this care is an LE with pwr door locks.
Thanks,
Randy
Old 01-28-2006, 12:24 PM   #15 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
If the key opens the trunk, driver door and turns the ignition it is should be the master key. If it doesn't unlock the passenger door only then that lock is probably frozen or maybe someone replaced it before you bought the car. The valet keys would open the doors and turn the ignition but wouldn't open the trunk, glovebox or the remote trunk lever in the cabin.
Kep
Trunk Stucked, locked and sealed off!!! wind_4ever Archived Corolla threads 16 09-03-2006 10:16 PM
DIY sort of Electronic Trunk Pop Anshu General Discussion 3 06-17-2005 10:30 AM
Looking for MKIII trunk lock cylinder 88SupraTurbo Supra Forum 0 06-20-2004 09:08 PM
Trunk Problem yrmac Camry & Solara Lounge 2 05-08-2003 02:42 PM
