4 Runner Flywheel fit Camry? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-27-2006, 05:54 PM   #1 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
2nd Generation 4 Runner Flywheel fit Camry?
Does anybody know if the '88-'94 4-Runner V6 flywheel will fit on a '90 V6 Camry. I know that they use a VZ engine also but I am not sure about the flywheel.
The plan is to modify my Gen2 V6 Camry from auto to manual. I have located a tranny, but no flywheel. A new Camry flywheel from Toyota is about $360, and I have located a 4-Runner flywheel for a very good price.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 01-27-2006, 06:52 PM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
might have a bolt spacing or thickness problem as they run R151(?) boxes, not our S and E boxes.
why not just go all out and get a fidanza lightweight? cheaper then OEM.
terrastrife is offline   Reply With Quote
Old 01-27-2006, 08:49 PM   #3 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Hmm thats an interesting question. Somehow though, i don't think it will. Since the Truck is RWD, the positioning of the clutch and parts would be different. I have a feeling that the flywheel would be thicker (quite thick actually), wheras the FWD one is thin. Bolt pattern would be the same for sure. All V6 FWD flywheels are the same (from 1988 to 2001 and possible later, havn't checked). So you could use ANY of them, they all use the same bolt pattern and are all the same thickness. Also, the MR2 3SGTE (SW20) flywheel is the same bolt pattern and will fit, however is 0.5" too small and MAY slip, since the V6 has quite a bit of torque. On my conversion, I used a 1993 3VZ-FE flywheel. Bolted in and to this day is working 100%.
PS. If you need any info/pics/advice, let me know (or others of course) because I have done the swap myself and have lots of info.
JetspeedCamry is offline   Reply With Quote
Old 01-28-2006, 04:14 PM   #4 (permalink)
Donald's Avatar
I looked at the Fidenza Flywheel as Terrastrife suggested, but the price is not much better that stock, but would be a better buy for sure.
I am going to expand my search to include the later models as you suggested Jetspeed.
I'll hit you up if I need any help, and I'll let you know if I am successful in my search.
Thanks guys.
2002 - 2005 Toyota Camry review! Lexusfreak 5th & 6th Generation (2002-2006 & 2007-2011) 2 03-27-2006 03:43 AM
does the gen5 radio fit in the gen3 Camry? Camry-rulez 3rd & 4th Generation (1992–1996 & 1997–2001) 2 12-25-2005 11:40 PM
Would a camry motor fit a sienna without any mods? tousi Camry & Solara Lounge 22 10-04-2005 01:30 PM
Does Gen3 or Gen4 Steel Wheels fit Gen2 Camry? bjturlington 3rd & 4th Generation (1992–1996 & 1997–2001) 1 09-01-2005 09:22 PM
will some Lexus ES250 parts fit on my 89 Camry DX? ubongen 1st & 2nd Generation (1983–1986 & 1987-1991) 4 02-17-2004 03:19 PM
