Nasty Colored Coolant - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-28-2006, 11:55 AM   #1 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
Noticed my coolant looked kinda dark brown. Flushed it, and now after a few days it looks brownish again. WTF?
WhiteRabbit is offline   Reply With Quote
Old 01-28-2006, 12:35 PM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
headgasket?
youre getting oil into the coolan lines.
terrastrife is offline   Reply With Quote
Old 01-28-2006, 12:44 PM   #3 (permalink)
Dealer Tech..not Toyota
Axel Kain's Avatar
View Axel Kain's Photo Gallery
possibly rust in your radiator.
Quote-Terrastrife: Axel the confusion specialist!
-1992 Camry V6 XLE- *3VZ-FE* (with a dead auto trans.) <SOLD!
Newest addition- 1987 300zx Turbo! what a blast!
Axel Kain is offline   Reply With Quote
Old 01-28-2006, 01:00 PM   #4 (permalink)
but thats what flushing is for.... rust wouldnt come back that quick.
check your oil, does it look like theres coolant in it?
Old 01-28-2006, 01:10 PM   #5 (permalink)
Pabloso
project92camry's Avatar
View project92camry's Photo Gallery
wouldnt u have white smoke if u had coolant mixing with the oil ?
project92camry is offline   Reply With Quote
Old 01-28-2006, 01:10 PM   #6 (permalink)
Axel Kain's Avatar
well, then youre prolly right, ^ check and see if the oil looks cloudy/foamy/ wierd...i do kinda hope it isnt the head for your sake!
Old 01-28-2006, 01:46 PM   #7 (permalink)
no. there isnt supposed to be oil in the combustion chamber, this is what the 3rd piston ring is for (or 2nd in 2 ring jobbies) its to scrape the oil so it is NOT going to burn.
what part of water+oil=burn anyway? =)
white smoke if you had water in the combustion chambers, blue for oil.
but there might be a leak between the oil and water passages somewhere not into the chambers themselves.
Old 01-28-2006, 02:34 PM   #8 (permalink)
lalo's Avatar
View lalo's Photo Gallery
Does it get foamy like Capuchino at the top of your Radiator CAP?
If so I would recomend also checking you Engine oil, IF you engine oil is Foamy like your Radiator Cap then you have a problem
IF Engine oil is ok then mostlikey The oil cooling lines form your tranny are broken from inside your Radiator and your spilling Tranny oil in your cooling system.
Take care of this quick or else you can damage your transmission.
Ignorance more freely begets confidence than does knowledge.
lalo is offline   Reply With Quote
Old 01-28-2006, 02:38 PM   #9 (permalink)
Lex Zues!
RedPhoenix's Avatar
iTrader Score: 12 reviews
View RedPhoenix's Photo Gallery
did you flush all of it out? could be the stock toyota red fluid.. after a little that stuf flooks brown.
Sold ^
Originally Posted by dysk8forlife
supercharger whine>girlfriend whine
RedPhoenix is offline   Reply With Quote
Old 01-28-2006, 04:00 PM   #10 (permalink)
Gameroom cash: $926800
iTrader Score: 13 reviews
View ASG14's Photo Gallery
^ I was gonna ask if it was actually FLUSHED, or just changed.
5 Lug Corolla WHAT?
Old 01-29-2006, 07:51 AM   #11 (permalink)
View hclee25's Photo Gallery
^^^ if you just drained the radiator, there was still coolant in the engine, and after driving a while, you are mixing the new coolant and the old brownish = brownish
hclee25 is offline   Reply With Quote
Old 01-29-2006, 12:23 PM   #12 (permalink)
TN's furry friend
i ran the engine until it was at operating temp with the heater on and rad cap off, then i drained it and flushed with water. doesnt that get all of it out? ill try to do another flush and drain both the rad and engine block next time i guess.
Old 02-09-2006, 11:43 AM   #13 (permalink)
View hooRAH's Photo Gallery
I just came across your thread and wanted to let you know that this is somewhat normal. I flushed out the system (really flushed) in our camry and within a few days it was brown again. Just the other day, I cleaned out the resivoir and refilled with fluid, turned brown within a few days. Dunno why it does this, but I doubt its your headgasket.
01 BMW 330Ci - 5spd / 93 BMW 525i 5spd-SOLD/ 98 Camry LE
hooRAH is offline   Reply With Quote
Old 02-09-2006, 10:36 PM   #14 (permalink)
TN's furry friend
^hmmm....intriguing
thanks for your reply
Old 02-11-2006, 05:37 PM   #15 (permalink)
View chesstompowell's Photo Gallery
Normal?
There's no f'n way the new coolant should be turning brown in such a short time. You've definitely got oil leaking into your coolant.
chesstompowell is offline   Reply With Quote
1997 Coolant & Differental question.. NorthernIllinoi Archived Corolla threads 6 10-25-2005 09:03 PM
Toyota Camry Coolant Problem vkbajoria Camry & Solara Lounge 14 03-30-2005 08:28 AM
TB Coolant bypass. CrawlingEye Camry & Solara Lounge 24 09-11-2004 11:03 PM
