Wagon RSB: OEM vs. Whiteline? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-28-2006, 01:26 PM   #1 (permalink)
View chasman's Photo Gallery
2nd Generation Wagon RSB: OEM vs. Whiteline?
Hi GEN2ers!
How would you characterize the differences between these two rear sway bars for a daily driver?
  • How much of a performance improvement can one expect?
  • Will the ride be negatively impacted?
  • Are there any safety issues such as in winter?
  • Any other considerations?
Thanks!
Chasman
202k one-owner
87 I4 Camry Wgn
ES250 Strut Brace, Tokico Blue, Ceramic pads
Falken ZE-512, Goodyear Eagle UltraGrip H-rated M&S
chasman is offline   Reply With Quote
Old 01-28-2006, 01:43 PM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
a noticible one
slightly firmer rear ride
snap oversteer?
so you drive hard enough to need it?
terrastrife is offline   Reply With Quote
Old 01-28-2006, 01:54 PM   #3 (permalink)
Hi terrastrife,
Could you describe "snap oversteer"
"so you drive hard enough to need it?"
The car is a daily driver - not autocross. Is the Whiteline designed for competition applications only?
Thanks!
Chasman
202k one-owner
87 I4 Camry Wgn
Old 01-28-2006, 03:05 PM   #4 (permalink)
Originally Posted by chasman
Hi terrastrife,
Thanks!
id suggest new tyres first before changing suspension components =) (edit ok you got decent tyres already)
i cant describe snap oversteer because how a car behaves is down to the driver.
if you feel the front end needs more turn in then get a rsb if you want ^^
Old 02-12-2006, 01:46 PM   #5 (permalink)
2nd Generation Whiteline vs. OEM Rear Sway bar
Hello All,
I'd appreciate if someone who's installed a Whiteline RSB could share the results of their upgrade.
Thanks!
Chasman
202k one-owner
87 I4 Camry Wgn
Old 02-12-2006, 02:58 PM   #6 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
I have installed a Whiteline RSB into my Gen 2. I noticed a nice improvement in turn in. I don't really "throw" my car around, so maybe i'm not noticing the full result, but im happy with what it has done. A 90 degree corner for example, can be taken now without nose feeling as if it wants to go into the other lane. And round-abouts can also be taken with more agility. The poly-bushes also help alot.
JetspeedCamry is offline   Reply With Quote
Old 02-12-2006, 08:38 PM   #7 (permalink)
Thumbs up Thanks for the reply JetspeedCamry.
Which bushings are part of the ploy-bushing kit?
Which do you think helped more, the Whiteline RSB or the poly-bushes?
Thanks again!
Chasman
202k one-owner
87 I4 Camry Wgn
Old 02-12-2006, 11:23 PM   #8 (permalink)
VeeZed
Thanks again!
The RSB bushings....they hold the sway bar to the chassis.
IMO, the bushing's helped more. (maybe coz mine were soft and old)...but it feels great with the firmer and more accurate suspension. The RSB helped alot too...but it helps more so when your "thrashing" the car around corners and such..whereas, you feel the effect of the bushings more when driving normally (which is what it do usually :P).
Old 03-18-2006, 12:12 PM   #9 (permalink)
2nd Generation Snap Oversteer: Wagon RSB: OEM vs. Whiteline?
I found the following description of snap oversteer:
Per http://en.wikipedia.org/wiki/Front_wheel_drive
"Snap oversteer also known as lift-off oversteer. The virtue of weight over the drive wheels also makes the rear end of the car exceptionally light. In a hard cornering situation, slight weight transfer to the front of the car (ie from lifting off throttle) can easily result in a unrecoverable spin, certain cars such as Peugeot 306 Xsi are well known for this characteristic."
We do not want to make any modifications to our car that would increase the likelihood of an unrecoverable spin.
Any thoughts?
Chasman
202k one-owner
87 I4 Camry Wgn
Old 03-18-2006, 12:38 PM   #10 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $407595
View atobe's Photo Gallery
yeah i was in a integra with when a snap oversteer happened on the freeway ... we spun all the way around then i saw cars comming at us... but no one got hit or hurt... that didn't have upgraded rsb .. it's all about driver than the bars itself
Old 03-18-2006, 11:55 PM   #11 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $307675
Any thoughts?
Sounds like its time to learn how to drive the car. My old Camry (granted, not a wagon) when it had an upgraded rear and stock front has a *slight* tendancy towards oversteer. Just don't be stupid and lift the throttle in corners - even then, the oversteer is controllable if you know what you are doing.
-Charlie
Old 03-19-2006, 11:32 AM   #12 (permalink)
Question Front & Rear Sway Bars?
Should both front & rear sway bars be upgraded at the same time to maintain balanced handling?
Thanks,
Chasman
202k one-owner
87 I4 Camry Wgn
Old 03-19-2006, 11:45 AM   #13 (permalink)
Pochacco Owns Me
atobe's Avatar
that would be ideal if $ allows
Old 03-19-2006, 12:15 PM   #14 (permalink)
Question Btr38 + Oem Fsb?
Per the Whiteline application listing, Camry 87-92 SV20-21 sedan wagon 4 cyl:
  • Rear BTR38 - 18 mm diameter
  • Front BTF91 (threaded end bar - for off road only) - 27 mm diameter
  1. Since it appears that Whiteline only has one choice for the FSB which is for off road only, is the BTR38 designed to work with the OEM FSB?
  2. How much larger is the diameter of the BTR38 compared to the OEM RSB?
Thanks,
Chasman
202k one-owner
87 I4 Camry Wgn
Old 03-19-2006, 04:53 PM   #15 (permalink)
Pochacco Owns Me
atobe's Avatar
it's really not for offroad use only it's just stiffer than OEM you're gonna be feeling the bumps in the road more than OEM...
here's a comparision
stock whiteline % increase in torsion
rear 15mm 18mm 107%
front 24mm 27mm 60%
that's assuming both are made out of the same material and bleh bleh bleh but you get the idea it's just stiffer than the OEM bars..as with any suspension upgrade it's gonna be like that a stiffer ride.. even changing to poly bushings it's gonna make you feel the bumps more.
i did buy both swaybars in the groupbuy last month it should be here in another month so i'll tell you how i like em once i put them in
Whiteline; Superpro and Dobinson Group Sale raptorracing Supporting Vendor Sales 222 03-09-2007 05:51 AM
Where should I order my Whiteline RSB from? mystickid Camry & Solara Lounge 17 02-05-2006 10:41 AM
Do I need any other components with a Whiteline RSB purchase? mystickid Camry & Solara Lounge 11 11-11-2005 09:48 AM
Whiteline RSB lateral movement brink Hardcore Tech and Competition 13 09-17-2004 02:03 AM
