Help with camber kit adjusting!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-25-2002, 02:48 PM   #1 (permalink)
Gen 2 Pimp
phat91camryLE's Avatar
View phat91camryLE's Photo Gallery
Hello all
I lowered my car and have just bought camber kits for all my struts. I was just wondering how I should set them. I got the Ingalls Camber Adjustment Kits for my 1991 Camry. Should I go with a negative cmaber on the front and a more positive in the back? What should I know about this?
Thanks guys,
Matt
phat91camryLE is offline   Reply With Quote
Old 12-25-2002, 09:48 PM   #2 (permalink)
View DIRTBIKEZ's Photo Gallery
You would probably be best off takeing it to an alignment shop. When I installed my Ingalls cam bolts I was told by 3 alignment places that they could not allign my wheels because they used a computer alignment system, therefore with altered suspension, the computer would not be able to give accurate readings. (Which I do not completely understand/nor totally believe) So anyway, thats what I did. I took it to a forth guy who did it for about $100.
DIRTBIKEZ is offline   Reply With Quote
Old 12-26-2002, 06:15 AM   #3 (permalink)
SCCA Tech Services
Hotwheelharmer's Avatar
View Hotwheelharmer's Photo Gallery
Dude those three shops are full of crap. They just didn't want to align it. If it is a computer control alignment rack then they can get in the computer and change the ride heigth of the car to waht it is and then go from there and align it right they are just too lazy about doing that because they have to do some measuring.
Brian Harmer
SCCA Solo Technical Assistant
Solo National Rules: http://www.scca.com/documents/Solo%2...lo_Rules_2.pdf
FastTrack: http://www.scca.com/contentpage.aspx?content=78
Hotwheelharmer is offline   Reply With Quote
