Red Coolant A Must??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-28-2006, 04:20 PM   #1 (permalink)
View 94_v6_camry's Photo Gallery
Hi guys,
I was told by one of the mechanic that you MUST use red coolant from Toyota else the radiator will clog up and resulted in damage....is he right????
Cheers
94_v6_camry is offline   Reply With Quote
Old 01-28-2006, 04:28 PM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
No he's not, green coolant will work ok but the red from toyota IS the best for our cars.
Do NOT use dex-cool!! (Orange) That WILL clog.
雄のハヤブサ
Tercel GTS is online now   Reply With Quote
Old 01-28-2006, 04:30 PM   #3 (permalink)
Ok thanks for the fast reply.
Can i also ask what is the best procedure for flashing the radiator???
Cheers
Old 01-28-2006, 04:40 PM   #4 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
Red is probably best, although my camry has probably seen all sorts of coolants and has yet to experience problems.
Im not trying to be a smart ass but the best way to flush a radiator is to take it to a pro.
nodrogkam is offline   Reply With Quote
Old 01-28-2006, 10:03 PM   #5 (permalink)
The Other White Meat
terrastrife's Avatar
you have a 3vz-fe
theres nothing to corrode.
cheap green is fine.
ive had green in for the last year and it hasent even had a hint of changing color.
terrastrife is offline   Reply With Quote
Old 01-28-2006, 10:10 PM   #6 (permalink)
Well few months back i was using one of the powder to stop the radiator leaking coolant, now i have enough money to fix it and i want to make sure it's all good !
Old 01-28-2006, 11:06 PM   #7 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
draining the radiator is probably only 1/2 of the coolant in the system, the other half remain in engine, you probably need to keep engine running and flush the coolant out of engine with running water from garden hose.
bronzemaxell is offline   Reply With Quote
Old 01-28-2006, 11:34 PM   #8 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
You can use a couple aspirin tablets to keep the thermostat open so that the coolant can flush out. But if you do that, you can also disconnect the hoses from the engine and stick the hose right into the engine.
Some engines also have a drain on the engine block somewhere. On the 5SFE, you can get to it by lifting the car and looking at the back of the engine block.
2007 Camry 2.4L 5M
Old 01-29-2006, 12:15 AM   #9 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
red or green coolant will soon be unavailable because they are sweet and kill animals. they have a new mix now that works in all cars and replaces all colors and is supposed to be safer for the environment.
WhiteRabbit is offline   Reply With Quote
What are the ASTM ratings for Toyota Red Coolant? ladd2 Camry & Solara Lounge 0 01-09-2006 11:18 AM
1997 Coolant & Differental question.. NorthernIllinoi Archived Corolla threads 6 10-25-2005 09:03 PM
Red versus Pink Coolant Psylocke Archived Corolla threads 8 07-29-2005 10:44 AM
Toyota Camry Coolant Problem vkbajoria Camry & Solara Lounge 14 03-30-2005 08:28 AM
