Please help.spark plug tube o rings stuck - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-28-2006, 10:25 PM   #1 (permalink)
V6LE_CAMRY's Avatar
View V6LE_CAMRY's Photo Gallery
3rd Generation Please help.spark plug tube o rings stuck
Well i got to both valve cover and when i was taking the spark plug tube o rings only the inner rubber/plastic colud go out, The rest of it(the oring wall) is stuck to the valve cover. When i try to pry it out with a flat head screw driver only vry small pices come off. Can any tell me how to get them off without damging the covers? Oh and i noticed that the rea cover's oil was red and the front cover oil was mostly brown with black stuff all over it.(no sludge)
Thanks.
V6LE_CAMRY is offline   Reply With Quote
Old 01-29-2006, 09:35 AM   #2 (permalink)
lalo's Avatar
View lalo's Photo Gallery
That sucks, it happen to me before, Just get some realy long Needel Nose Pliers and pull it out.
Ignorance more freely begets confidence than does knowledge.
lalo is offline   Reply With Quote
Old 01-29-2006, 01:34 PM   #3 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
i pulled up the little tabs on the side holding it in and then ripped them out, when i put them back in it closed the tabs back using a large socket.
and broke 3 vlave cover bolts in the back >.>
^ and leaving it that way!
Old 01-29-2006, 02:20 PM   #4 (permalink)
V6LE_CAMRY's Avatar
Thanks guys, i got them out by ptuuting wd-40 and then prying them from the bottom of it woith a large flat head screw driver.
Since im already this far decided to buy new plugs for it. They are ngk iriddiums. Are these plugs good? do you gap them? Thanks.
Old 01-29-2006, 02:49 PM   #5 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
yes, they're good
and it's still good practice to gap them to spec, though they tell you you don't have to
HaHa
Old 01-29-2006, 02:50 PM   #6 (permalink)
Cressida nut
Gameroom cash: $249445
View kamesama980's Photo Gallery
you dont gap them. iridiums are a bit excessive for a NA engine dont you think? to help with the problem in the future, throw some dielectric lube goop on the inside of the boots/outside of hte plugs. you can get it from wherever you got the plugs for like $.50 or something.
'90 Cressida, 7M-GE, M5 (2JZGE-T coming)
'91 Toyota Pickup, 22R-E, M5
'90 Suzuki VX800
"You don't get to judge me for how I fix what you break"
kamesama980 is offline   Reply With Quote
Old 01-29-2006, 05:04 PM   #7 (permalink)
V6LE_CAMRY's Avatar
i srewed up on the new orings, When i installed the new ones and it was time to put it back on i noticed that they were backwards so i too them out by prying them from the bottom. so then i put them back but when i used something to put it back i hit it with a hammer and some alunimum tube thing so i kind of ripped one and put rtv on the whole round thing to prevent it from leaking. I hope it does't leak. If they were availavle at the auto store i would of gone and picked up a new set but they are a special order. Now going to continue putting ther rest back which is almost everythig ecept the valve covers.
Old 01-29-2006, 08:19 PM   #8 (permalink)
V6LE_CAMRY's Avatar
im done and started it up. so far no leaks. When i first started it up the idle speed was 1900 rpm(cold), about 100 more than usual, but then it settled to normal rpm after a few minuits. I also niticed that my idle speed when fully warmed and in reverse was 800 again 100 less than normal. But then after just afew miles it went to normal. Also when i disconnected the throttle body there was to lowe hoses that flowes antifreeze in it. Does that the termine the idle speed depending on the cooant water?
Help!! Removing stuck spark plug in Camry 2.2 skewe Camry & Solara Lounge 23 06-04-2007 05:45 PM
#2 Spark plug is black all others are fine. Is it the rings or valve stem seals? Brown87Rolla Archived Corolla threads 3 11-03-2006 07:09 PM
Spark Plug Tube Nuts?? 97TXCamry Camry & Solara Lounge 6 06-02-2005 04:41 PM
Stuck plug wires.. jackfrost1031 Camry & Solara Lounge 7 04-16-2005 07:10 AM
How big are those spark plug tube nuts? coolchu001 Camry & Solara Lounge 8 12-08-2004 02:57 AM
