Oil Lamp turned on... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-29-2006, 02:32 PM   #1 (permalink)
syP
View syP's Photo Gallery
1998 Camry XLE v6 auto....
100k miles on it.. maintained very well... just got the oil change done 600 miles ago
The oil lamp turned on, on the dashboard.
Car ran fine still made it home ok... nothing out of the ordinary, no oil drips either.
suggestions??? Before i take it to the dealership to pay an arm and a leg to fix it.
I was thinking perhaps the oil pressure sender?
syP is offline   Reply With Quote
Old 01-29-2006, 02:48 PM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
quite potentially
but when you say nothing out of the ordinary, did you check the oil level?
you said that you GOT it changed- maybe they overfilled / underfilled by a lot
HaHa
Old 01-30-2006, 03:59 PM   #3 (permalink)
Gameroom cash: $304355
Don't continue driving the car. Check the oil level like Eye8pussies suggested. If the oil level is low or high, correct it. If the oil level is not abnormal, then don't drive the car. Have it towed in some place. They will first remove your oil sending unit and install a mechanical gage and check the actual oil pressure reading. If it is in spec, then it is your sending unit that is defective and they will replace that. Keep your fingers crossed for that because that is a cheap fix. If it is actually low on oil pressure, then they will have to look further to determine is the pressure is low due to a bad oil pump or even worn out engine bearings. Like I said before, don't drive it until you get this checked out.
Mike
TOYOTA ENGINES AND OIL SLUDGE - WALL ST JOURNAL bondobondo General Discussion 99 02-02-2007 06:54 PM
Oil Leak Help!! 94 Celica bramile Celica Forum 6 08-29-2006 04:35 PM
Oil Pressure sensor/switch lcarocha General Discussion 1 07-06-2005 05:22 PM
Need very hot temperature motor oil suggestions. Blek General Discussion 20 07-15-2004 09:59 PM
What I found when changing the oil. Kooter Camry & Solara Lounge 2 10-19-2003 06:37 PM
