Need Some HELP - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-29-2006, 11:41 PM   #1 (permalink)
View 89buildcam's Photo Gallery
2nd Generation Need Some HELP
Alright heres the deal, i work for a toyota dealer and really support there products all the way. I just picked up an 1989 2.5L V6 Camry. All ive done is rebuilt the engine and install a system. Im getting ready to put 17" wheels on it and have been looking for a drop. My question is what is everyone using to drop the v6 camry. A friend that i work with had a similar camry with 17 s and he used the intrax springs but he said that they were made for the 2.0 and after a month or so he couldnt keep from bottoming out. Has any one else had this problem or should i not worry about. Does anyone actully make a drop for the v6 or does anyone know a better way to do the drop.
89buildcam is offline   Reply With Quote
Old 01-29-2006, 11:57 PM   #2 (permalink)
The Rent is Too Damn High
Deuce's Avatar
View Deuce's Photo Gallery
gen 2 strut discussion
gen 2 lowering spring thread
I don't need a sig, I'm 31.
Deuce is offline   Reply With Quote
Old 01-30-2006, 12:41 AM   #3 (permalink)
Alright i read through both discussion and it really helped but do you think that the struts will resolve the problem of rubbing. Will they make that big of a difference.I just talked to my friend and he says that he still has the intrax springs that he used and that i could have them so do you really think that the struts will fix the problem or not becuase im ready to order if they will.
Old 01-30-2006, 12:55 PM   #4 (permalink)
Deuce's Avatar
rubbing against the tire?
if its rubbing against the tire, try smaller width tires or a spacer. if its strut rubbing against the spring, see if there's a slimmer strut available for gen 2s.
