From a guide by Zoni, listing the parts needed to swap the Tranny AND engine to a 3sgte...
"for a 3sgte i4 turbo swap + manual tranny, you need...
-motor, 3sgte
-uncut wiring harness, 3sgte
-ecu, 3sgte
-igniter, 3sgte
-map sensor, 3sgte
-tranny, 1mz
-clutch, 3sgte
-flywheel, 3sgte
-release bearing, either
-shifter assembly, 1mz
-cables, 1mz
-center console&shift boot (if you want to do it right), 1mz
-clutch pedal
-brake pedal
-master cylinder
-clutch line
-slave cylinder should be included with the tranny.
-axles, 1mz
-hubs, 1mz
-calipers, 1mz
-rotors, 1mz
-motor mounts from the 5sfe work!
-ps pump, a/c pump, alternator from the 5sfe work!!!!
-misc parts, only a few
-maintainance parts (oil filter, spark plugs, all fluids)"
Okay, I'm dumb. (sorry for trying to collate all this info in one place!)
So... I think that is a good list of parts to start with. Taking out the fact I am not putting a 3sgte in... What would I need? What don't I need?
I'll shut up for a while and let someone a lot smarter than me answer, and hopefully not make too much fun!
