:: quick help on my camry :: - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-30-2006, 03:09 AM   #1 (permalink)
iTrader Score: 6 reviews
View [khumbmela]'s Photo Gallery
zup TNers.. i just have a few quick question about my car.. it's 1996 i4 LE w/ 150k+ mileage.. just wanted to know if someone here have experience this annoying sound on their car..
1) when i start my car, it has a hissing sound and it stays untill i turned off the engine..
2) everytime i turned, there's this sound comming fron the passenger's side.. it's like cracking like that..
3) and finally, everytime i slow down on exit from freeway.. it was good.. but when i start on braking.. there's this knocking sound.. i think it's coming from the back..
anyone know what's this?.. i did try to search but i got no luck.. i appreciate all the help guys..
[khumbmela] is offline   Reply With Quote
Old 01-30-2006, 04:03 AM   #2 (permalink)
i'm sorry.. i accidentally pressed the "submit" button 4 times.. delete this pls.. thank you and sorry again,.,
Old 01-30-2006, 09:19 AM   #3 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $280492
View csaxon's Photo Gallery
Hissing is air, so look for loose, cracked, dried out, split or disconnected or missing vacuum/air hoses.
The crackling sound may by a CV joint. Look at the rubber boots on the shafts going to both wheels. Look for leaking grease and torn rubber boots.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 01-30-2006, 09:49 AM   #4 (permalink)
Moving Forward
View Cyorke's Photo Gallery
Hissing could be disconected vacuum hose. It is also possible youare hearing the air coming through the air filter box. Camry's are notoriously loud about this. Open the hood and try to figure out where the noise is coming from. I would think if it was a vacuum hose though you would be having some driveability issues. High/low idle, rough running or some other things like that.
The knocking noise when turning is most likely the CV axle. THe boot has broken and all of the grease in the boot that lubricates the joint is gone. NOw it is time to replace the axle. If you can do it yourself you are probably looking at 200 dollars or less for the part. If you ahve to have it done probably getting into the 300 dollar range.
Knocking when applying brakes is either warped rotors or drums. when you hear the noise do you also fel vibration in the steering wheel, if so it is most likely the rotors that need to either be replaced or machined. If you fell it more in the pedal or the seat of the car it is most likely the drums and the same thing you need to either replace or machine them.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 01-30-2006, 01:50 PM   #5 (permalink)
on cv axle.. just incase that's the problem.. will this one work?..
http://cgi.ebay.com/CV-AXLE-100-new-...QQcmdZViewItem
Old 01-30-2006, 01:58 PM   #6 (permalink)
Moving Forward
should work but 50 bucks for an axle seems awfully cheap. If you get it make sure they are going to stand behind the warranty they give you on it.
Chris
Old 01-30-2006, 04:05 PM   #7 (permalink)
The Rent is Too Damn High
Deuce's Avatar
View Deuce's Photo Gallery
axle cost, including repair at a shop for the passenger should cost no more than $200.
axle cost for the driver side should be no more than $240.
it is always better to replace your axle instead of just the CV boot because if its cracking, the axle itself may be damaged already, plus its only a $40 difference (average) between CV Boot repair/replace and axle replacement.
I don't need a sig, I'm 31.
Deuce is offline   Reply With Quote
Old 03-17-2006, 10:12 AM   #8 (permalink)
sae
View sae's Photo Gallery
I think I might have the same problem on my car. Stupid snow and potholes. I replace axles almost every other year.
sae is offline   Reply With Quote
Old 03-17-2006, 11:44 AM   #9 (permalink)
MOUTH SLAP!
Your Uncle Moe's Avatar
View Your Uncle Moe's Photo Gallery
Sometimes the loud noise coming from the power steering is the result of low fluid. I'd try adding some first. even IF IT LOOKS FULL TRY ADDING SOME fluid. The level stays high and goes down as you add more fluid. I dunno why. Same for the Brake fluid resevoir.
96 Camry V6 LE & 90 Eagle Talon TSI (AWD TURBO)
"Love is all you need to know and all you need to know is love is all you need to know."
Your Uncle Moe is offline   Reply With Quote
Old 03-17-2006, 01:34 PM   #10 (permalink)
sae
I am very sure mine is not related to the power steering because it only happens when I slow down.
The funny thing that the harder I slow down, the faster the ticking is (so it's obviously not related to the tire rotation speed).
I will check my brake fluid though.
FS: Misc Gen 4 Camry parts (engine/interior/exterior) got_trd Car Parts for Sale 41 08-01-2007 03:10 PM
GEn 4 camry solars glow guages ona gen 4 reg camry mystickid 3rd & 4th Generation (1992–1996 & 1997–2001) 15 05-18-2005 05:06 PM
96 Camry V6 LE: TRD supercharger? kman10587 3rd & 4th Generation (1992–1996 & 1997–2001) 11 07-16-2004 03:15 PM
looking to buy a new camry bulba Camry & Solara Lounge 2 04-25-2004 12:30 PM
2003 TOYOTA CAMRY XLE vs. 2003 HONDA ACCORD [NEW].. Macreative 5th & 6th Generation (2002-2006 & 2007-2011) 7 09-15-2002 01:10 PM
