need help! something is broken! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-31-2006, 11:16 AM   #1 (permalink)
AKA: KSNIPPY
nivek5sfe's Avatar
View nivek5sfe's Photo Gallery
3rd Generation need help! something is broken!
i was looking under the hood of my car today just to see how evreything was and i found something that is broken. please help me determine what this is form the pic. thanks!
nivek5sfe is offline   Reply With Quote
Old 01-31-2006, 11:32 AM   #2 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $407595
View atobe's Photo Gallery
coolant temp sensor ? doesn't look broken
Old 01-31-2006, 11:41 AM   #3 (permalink)
The Other White Meat
terrastrife's Avatar
remove the excess/broken end from the tube and just plug it back up =)
it just plug it back if it fell out.
terrastrife is offline   Reply With Quote
Old 01-31-2006, 11:51 AM   #4 (permalink)
Moving Forward
View Cyorke's Photo Gallery
it is actually calle TVV according to the repair manual taht is stickied at the top of the page. it is an emissions vacuum valve that works off of temperature. One of the two hoses goes to the charcoal canister and it looks like the other goes to the throttle body or something along those lines.
That being said it doesnt look like it is broken though. It looks more like one of the vacuum lines has just been pulled off. You should try pushing the hose back onto it. If that doesnt work then it is off to the junk yard or dealer. If it is jsut the hose that is the problem, like it has worn out and split you can go to autozone and buy some kind of connector and get a short piece of vacuum hose and attach it back that way.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 01-31-2006, 12:37 PM   #5 (permalink)
AKA: KSNIPPY
nivek5sfe's Avatar
Originally Posted by terrastrife
remove the excess/broken end from the tube and just plug it back up =).
thats what i ended up doing, although it feels as if it could come off fairly easily, i just have to see.
can you pick these up at auto zone or any place like that?
Old 01-31-2006, 02:09 PM   #6 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Cutting the excess broken end off is easyier said that done. These things (the BVSV i believe) are sooo brittle. One of mine is broken off completely at the base...no way to fix for me but to buy a new one! I don't know how critical it is, seemed to make no difference on mine.
JetspeedCamry is offline   Reply With Quote
Old 01-31-2006, 03:05 PM   #7 (permalink)
View karazy's Photo Gallery
Yes they are very brittle. The purpose is to burn the excess fumes from the canister.
karazy is offline   Reply With Quote
Old 01-31-2006, 06:07 PM   #8 (permalink)
V6LE_CAMRY's Avatar
View V6LE_CAMRY's Photo Gallery
is the top of it cracked? Just replace it and you will be o.k.
V6LE_CAMRY is offline   Reply With Quote
Old 01-31-2006, 08:06 PM   #9 (permalink)
AKA: KSNIPPY
nivek5sfe's Avatar
the top isnt cracked, just one of ther green pieces that stick out for teh hose to stick onto is broken off. but there is bare some of it still sticking out so i was able to stick the hose back onto it but it doent have that great or a connection.
How to remove a broken spark plug on my '93 Camry LE V6? Vibroseis General Discussion 4 03-03-2006 03:47 PM
Broken down and need help! dexterous2000 89-95 Toyota Pickup/Hilux 6 10-03-2005 10:26 PM
so my car got broken into... andyman61 Off Topic 12 04-27-2005 01:20 PM
broken Fuse again its getting annoying bowlofturtle Camry & Solara Lounge 19 06-11-2004 06:06 AM
broken CV joint and wheel hop wontonjohnny Camry & Solara Lounge 9 12-09-2002 10:46 PM
