P0301= Cylinder 1 Misfire Detected
Hopefully someone can help you diagnose your problem here.
But here's a good idea to look at the problem. If you think it is one of the things you just changed, try swapping them (plugs/wires) to different cylinder and see if the cel is still there. If the CEL is still there, I would say that the fuel injector will be the main suspect.
I have also read about the same problem, and the it was caused by broken exhaust spring.
