IIRC, there is a setup that has a bolted plate at this location, never seen it myself... apparently you can pull the shaft by unbolting this plate, weird... A lot of times, pulling the drivers side shaft you will catch the spring on the diff axle seal and tear it out, seal replacement is then required...ask me how I know..is that a spring in there I said to myself? Lucky I noticed it and it didn't fall into the trans...whatever can go wrong will is my motto...
00 Solara SLE V6 1MZ-FE, 16.5K miles "Garage Queen"
94 Camry LE I4 5S-FE
