Wich flex pipe should i use? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-01-2006, 07:17 AM   #1 (permalink)
View Camrymatic's Photo Gallery
3rd Generation Wich flex pipe should i use?
I need to replace my flex pipe. Which one should I use? I have a 94 i4. I am thinking number 10246 is what I need for my application. Any downside to using a regular steel pipe in place of the flex? If not I will just get a straight piece welded on and not bother with this one.
http://www.car-sound.com/catalog/accessories.aspx
Camrymatic is offline   Reply With Quote
Old 02-01-2006, 07:26 AM   #2 (permalink)
View noodlerooney's Photo Gallery
IIRC, the flex pipe is needed because of engine movement, without it, I would imagine it would tear the exaust system apart. As to the correct size, I would have to check the FSM. Seems this part is a weak point because of it's flexing (stating the obvious).
00 Solara SLE V6 1MZ-FE, 16.5K miles "Garage Queen"
94 Camry LE I4 5S-FE
noodlerooney is offline   Reply With Quote
Old 02-01-2006, 07:40 AM   #3 (permalink)
Moving Forward
View Cyorke's Photo Gallery
Yeah you probably dont want to replace it with a straight pipe. You will get much more vibration than you already do and every time you accelrate and the enginemoves it could over tiem break quicker than the flex pipe did or would.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 02-01-2006, 08:13 AM   #4 (permalink)
Lex Zues!
RedPhoenix's Avatar
iTrader Score: 12 reviews
View RedPhoenix's Photo Gallery
ill be running no flex for one day, and im scared about that lol.
Sold ^
Originally Posted by dysk8forlife
supercharger whine>girlfriend whine
RedPhoenix is offline   Reply With Quote
Old 02-01-2006, 08:56 AM   #5 (permalink)
The Other White Meat
terrastrife's Avatar
instead of running with no flex, just run without the whole exhaust so theres no chance of something breaking =)
terrastrife is offline   Reply With Quote
Old 02-01-2006, 12:36 PM   #6 (permalink)
3rd Generation
Ok, but is is the right size?
Old 02-01-2006, 01:03 PM   #7 (permalink)
no idea sorry, its gonna be welded on anyway so as long as its only as long or a bit shorter then the current one you should be able to get away with cutting th e old one out and welding the new one in.
Old 02-02-2006, 07:21 AM   #8 (permalink)
94 Camry I4: IIRC, stock exhaust diameter is 2", don't know the length of the flex pipe...
Old 03-07-2006, 03:46 PM   #9 (permalink)
Sux2BeMe
View kingkong's Photo Gallery
I am in the same situation and just went thru this. I cannot find any answer as to which flexpipe section to buy.
I took the car in to a local muffler shop, and they wanted $125 to weld one in there.
Looked online and found an entire downpipe for around $90 shipped + 5 for gaskets.
It's going in later this week, together with new engine mounts.
If you can find a muffler shop that won't rape your wallet, go for it.
kingkong is offline   Reply With Quote
Old 04-28-2006, 11:39 AM   #10 (permalink)
View toyomania's Photo Gallery
I just went through the same situation. I found a replacement flexpipe at a Midas Muffler shop for about $50. They flared the ends to fit my existing pipe (just under 2") and I welded it in. Check with your local muffler shops. The prices I found ranged from about $50 - $100. Just for fun, I called my local Toyota dealer - they wanted over $700 for the complete unit and didn't have a replacement flex section. That was my entertainment for the day!
toyomania is offline   Reply With Quote
Ques. about the Flex pipe (front pipe) VietBoi Camry & Solara Lounge 9 01-31-2011 04:14 PM
Preventing flex pipe from breaking on 1993 Corolla foomanji Archived Corolla threads 4 10-15-2005 06:44 PM
Camry Flex Pipe smileyiyun Camry & Solara Lounge 16 06-02-2005 11:11 AM
DIY Cold-Air Intake bondobondo Hardcore Tech and Competition 40 11-24-2004 01:41 PM
