Head Gasket Choices - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-01-2006, 01:10 PM   #1 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
2nd Generation Head Gasket Choices
So I seem to be leaking some oil...or, a lot of oil. I had bought this Fel-Pro Intake Manifold set about two years ago and it seemed to be decent quality.
I have heard *ahem* other things about this brand, so I'm looking for input here. What are your experiences? Gen2 advice would be especially appreciated, but I want to hear from anyone who has had good OR bad things happen with any brand and any Camry generation...
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 02-01-2006, 04:56 PM   #2 (permalink)
Just trying to turbo
theman33b's Avatar
View theman33b's Photo Gallery
I have a gen 2 and i realized that i leak alot from my valve cover, i have replaced the gasket twice already and i think the other bank is leaking right on the exhaust smells lovely. are you sure its coming from the head gasket?
theman33b is offline   Reply With Quote
Old 02-03-2006, 03:31 PM   #3 (permalink)
Mad Scientist-In-Training
toyrolla's Avatar
View toyrolla's Photo Gallery
2nd Generation
I've used Fel-Pro products on my Camrys, as well as on my future father-in-law's 96 Chrysler New Yorker.
One of the keys to gasket application is a clean mating surface.
If you apply Fel-Pro (or any gasket) with the mounting surfaces clean, you shouldn't have any problems.
Usually what I do before applying a gasket is I clean the mating surfaces using a clean rag and gasket removal spray, then I follow-up with another clean rag with brake cleaning spray.
I usually apply a light spray on the rag that's wrapped around my index finger, then follow around the mating surfaces until all oil and junk is removed. Then I follow up with the same procedure using brake cleaning spray.
Sounds a bit anal, but trust me when I tell you; it's worth it.
You really want the mating surfaces *clean* before you apply the gasket.
Good luck!
Regards,
Toyrolla
__________________________________
88 I4 Slushie *sold*, 89 I4 5Sp *sold*, 89 V6 5Sp *sold*, 82 Corolla, 72 Datsun 510, 88 Toyota Minitruck.
toyrolla is offline   Reply With Quote
Old 02-04-2006, 06:15 AM   #4 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
I've used Fel-pro intake/exhaust manifold gaskets, without problems.
What I like to do, especially with head gaskets is use a scotchbrite sponge (the rough green side) and clean the mating surfaces. Or use a right angle air die grinder with screw on 3M polishing pads.
As for the head gasket, buy one from a Toyota dealership. IIRC its $40 or so for the head gasket + head bolt set.
"Skoolin' the unlearned!"
Old 02-04-2006, 10:15 PM   #5 (permalink)
Bullitprooph
Thanks all, that's good advice. As for your question, theman, I'm sure it's the head gasket. Believe me, I tried to convince myself it was something else--but I redid the valve cover gaskets last year (the easiest fix, of course) and they're still very obviously good.
I'll actually try to take everyone's suggestions for mating surface prep work. I know how insanely important it is. I don't want to be doing this again in six months!
And 88LE, I really hope you're right on the pricing! I would have expected $150-plus from dealer...
Head gasket theory needed peterng 89-95 Toyota Pickup/Hilux 4 01-15-2006 09:51 PM
head gasket ladydanyell Camry & Solara Lounge 10 09-27-2004 05:45 PM
