What should I do to fix this? I just had these put in 2 weeks ago and one has already condensed. Is it easily able to be fixed or should I return it for a new one? Thanks
also the same tailight has now begun to blink much faster than normal, which I believe is caused by a bulb to go out. Is this related to the water in the light?
possible idea, pull the bulbs, and shoot a blowdryer into the sockets...to evaporate the water inside, if it does this again...bad seal somewhere.
__________________ Quote-Terrastrife: Axel the confusion specialist!
-1992 Camry V6 XLE- *3VZ-FE* (with a dead auto trans.) <SOLD! Newest addition- 1987 300zx Turbo! what a blast!
if you jsut bought hem 2 weeks ago then I would try to return them. Hopefully whoever you bought them from has some kind of warranty. If not you are going to have to take them apart and reseal more than likely.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
if its like the headlights, should just be able to stick the lense in the oven 115 for like 20 min. Let it heat up and pull the lense off the assembly. Reseal it with silicone.
alright so i cross referenced and found a post about how TONY used a heat gun? Where can I get silicone, i plan on just doing this in shop one day, my teacher is real cool and I have a heat gun, and hot glue in there
Before you do anything, make sure that it is a bad seal. On a dry sunny day around 10am take the bulbs out. Face the lights toward the sun. Let the heat from the sun evaporate the water. Plug the lights back in, make sure they are inserted tight. If moisture does happen again then you have a problem. With a heat gun you may not get all of the moisture out depending on how you are heating it up. The oven is another option to melt the seal and reseal with silicone. I think silicone just gets messy and would rather avoid it if possible. It may just be as simple as it just happened to be a humid day when installed and trapped some water molecules in your lights.
