Confirm Torque specs please - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-01-2006, 07:07 PM   #1 (permalink)
View green94camry's Photo Gallery
Ball Joint to controll arm nuts=94 Ft Lbs
Ball Joint to steering Knuckle=90
CV Axle allen head bolts=47 Ft Lbs
Axle shaft hub/spindle nut 257 Ft Lbs
Just would like confirmation that these specs are correct.
BTW there is a gasket on the end of the axles but you can use a bead of silicone also. I used the supplied gasket that came with the axles the manual never mentions it in the proceedure, but the gasket is shown in the exploded illustrations of the parts???
green94camry is offline   Reply With Quote
CV Torque specs diverjeff Camry & Solara Lounge 1 11-11-2005 11:28 AM
2006 suspension torque specs Turtleboy 2nd Generation (2005+) 0 11-04-2005 03:50 PM
Cam Gear Torque Specs? gtiwayne MR2 Forum 2 07-13-2005 11:44 PM
no more frowning on A/T cars! Go! project trueno General Discussion 12 12-14-2001 09:54 AM
