Problem with Water Pump/Timing Belt - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-01-2006, 08:05 PM   #1 (permalink)
View 92ToyotaCam's Photo Gallery
Hi Everyone,
I have a 1992 Toyota Camry with only 60k miles on it. Engine compartment started making abnormal noise and was leaking coolant, I determined it to be the water pump. Figured might as well replace timing belt and other belts at the same time. I parked the car for a week, and then today was going to drive it over to a service garage.
Car went about 2-3 blocks, then lost power. Engine would just go put-put-put and not go anywhere. Was able to turn off car and it would crank over, but was hard to start and would only run at a few hundred RPM's. Had to tow the car back to my house, because it wouldn't drive anywhere. Could water pump have completely frozen up and timing belt was still intact trying to run around it? If belt snapped, car wouldn't run at all correct?
Also, this year camry is a freewheeling engine, so if belt was to break, damage would normally not occur to valves, correct?
Anyway, would just like to know a little bit more about whats wrong, before I go to the garage with it.
Thanks for anyones help,
Shane
92ToyotaCam is offline   Reply With Quote
Old 02-01-2006, 08:22 PM   #2 (permalink)
Dave's
Gameroom cash: $122050
View Dave's's Photo Gallery
Pump could have locked up for a second and caused the timing belt to jump time without actually breaking. (Just one possiblity) This could result in an engine which would start but not run well. Don't think it should do real harm to the engine but you probably don't want to drive it.
Dave's is offline   Reply With Quote
Old 02-01-2006, 10:08 PM   #3 (permalink)
Nad1370's Avatar
View Nad1370's Photo Gallery
^^ I agree. Waterpump gear gave out making the T-belt jump.
Nad1370 is offline   Reply With Quote
Belt problem, need help rice Archived Corolla threads 6 07-27-2005 03:25 PM
Celica 2001 SQUEAL noise (Drive belt? Water pump?) PLEASE HELP - Ahhhh! mgcelica Celica Forum 6 02-18-2005 04:06 PM
Confusing overheat problem. Water pump?? Luspher Camry & Solara Lounge 7 02-05-2005 11:59 AM
Changing CV boots, timing belt, water pump, spark plugs... Silver Streak General Discussion 4 08-03-2001 03:00 PM
