Would It Be? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-02-2006, 12:21 AM   #1 (permalink)
Camry LOVER!
View Azn_Stock_Camry's Photo Gallery
4th Generation Would It Be?
Hello, my name is pow, im 16 and i just inherited my parents camry. the problem is, its 1997 i4 automatic camry. what things performance wise would i be able to do to the engine? headers? intake? i know i could probably search for something but ive been searching for a while and havent been able to find anything. any help would be appreciated! thanks.
Azn_Stock_Camry is offline   Reply With Quote
Old 02-02-2006, 12:50 AM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
are you SURE its yours now? because youre gonna be doing serious work for it.
the 3 most serious but realistic upgrades are:
5 spd manual swap ~$1000
supercharger/turbocharger ~$2500-3000
and the quick and dirty option, nitrous. ~$700
if you cant deal with the downtime/cost you might just wanna go for a show look, dress up, kits/wheels etc.
terrastrife is offline   Reply With Quote
Old 02-02-2006, 03:08 AM   #3 (permalink)
Team Fat Kid Racing
V6camry99_1mz's Avatar
View V6camry99_1mz's Photo Gallery
Does anyone know what model manual transmission bolts to my 1mz-fe?
Camrys Rule... 1999 Camry LE V6 1mz-fe; Y-Pipe Dual Exhaust, Short Ram, & Front Strut Bar
2 Infinity Reference 1242w enclosed vinyl/carpet ported box built to thiele smalls parameters & Soundstream 600 watt amp; Pushing 155dB
V6camry99_1mz is offline   Reply With Quote
Old 02-02-2006, 03:34 AM   #4 (permalink)
the preferred one?
E153-73x where x is 2, 3, 4 or 5
there are 4 models, 2 open, 2 lsd, with different pinion counts
2 2 pinion open
3 2 pinion lsd
4 4 pinion open
5 4 pinion lsd
there is no way youre going to find a 735 =)
Old 02-02-2006, 09:15 AM   #5 (permalink)
Camry LOVER!
ohh i am down for that 5 speed manual thing. im sure its my camry but problems i have are things like where to go to get this done and where to get it.
Old 02-02-2006, 09:17 AM   #6 (permalink)
97camryman's Avatar
View 97camryman's Photo Gallery
Man I was once in the same boat as you. I had a bone stock 97 i4 automatic Camry and no car knowledge. I learned everything I could and I swapped to a 5 speed (S51) and shorteden the shifter, made a clutch hardline, installed an ACT upgraded clutch, remover the engine balance shafts, installed an unorthodox underdrive pulley, I lowered it 1.8 inches on Tein s-tech springs, tokico struts, added 18 inch konig wheels, Added clear corners, intake, redid the whole interior, shaved emblems, pinstripes, mudguards, added 4 twelves in the trunk, redid the gauges in blue, all the lights, added a hideaway liscense plate, deleted the air conditionig and now my new goal is turbo, I have made a downpipe and cutom fittings so far, autometer gauges in an a-pillar I made, supra injectors, fpr, fp, intercooler, bov, added a wideband o2 setup, the list goes on and on. http://i16.photobucket.com/albums/b1...grounds003.jpg
I would recommend the five speed swap highly, I can walk you through every step and answer every single question you would have. Good luck!
Home Page: http://www.cardomain.com/memberpage/506928/1
5S-FE Turbocharged @8psi with 5-speed auto to manual swap
97camryman is offline   Reply With Quote
