idle adjustment - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-30-2002, 01:16 PM   #1 (permalink)
View allmine97's Photo Gallery
idle adjustment
My idle speed is way too low (600) and it stalls and/or idle rough from time to time. How do I adjust the idle speed on a 97 camry 2.2L?? Do I need to replace the idle control valve or what??
allmine97 is offline   Reply With Quote
Old 12-30-2002, 04:22 PM   #2 (permalink)
Druken Postwhore
TRDragoon's Avatar
View TRDragoon's Photo Gallery
check your throttle body/link area...there should be a screw that stops the throttle valve from shutting completely closed....
BUT.....before you do that!!!!
check ALL your spark plugs and check for any wear or oil etc etc....so far every car i checked with low idle, the spark plug was always the problem.
The AE92 Master
UniQue_N_RaRe
TRDragoon is offline   Reply With Quote
Old 12-31-2002, 11:14 AM   #3 (permalink)
idle adjustment
thanks for the advice. I just put in new spark plugs, the old ones were fine. Checked the wires and they are fine too. I'm thinking that I have a leak in one of the vaccuum hoses since the needle likes to move around. Let me know your thoughts.
