Need Spanner wrench - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-04-2006, 08:12 AM   #1 (permalink)
View abcdef's Photo Gallery
Need Spanner wrench
I really need help on how to get the camshaft pulley out without taking the head cover off. will spanner wrench work since the pulley have no hole on them?. the pulley look exactly like one in figure 14. on this site. please help http://www.autozone.com/servlet/UiBr...3d8013e607.jsp
abcdef is offline   Reply With Quote
Old 02-04-2006, 08:59 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
You need to keep the motor from turning somehow.
Either remove the valve cover and use a wrench to keep the camshafts from turning. Theres a flat spot on the camshafts that you can put a wrench around.
Or hold the crank pulley still with a breaker bar and break the bolt loose on the cam pulley.
By the way, cross posting is not allowed.
timing belt - 1MZ-FE... need spanner wrench ?
"Skoolin' the unlearned!"
Old 02-06-2006, 05:33 PM   #3 (permalink)
95% Biker / 5% Driver
Digger1's Avatar
View Digger1's Photo Gallery
Question
Hi ABC,
What type of engine? What year is the car?
I may be able to help.
Digger1
"If you don't understand the technology you depend upon, you will someday be a victim of that technology."
Digger1 is offline   Reply With Quote
timing belt - 1MZ-FE... need spanner wrench ? BobES300 General Lexus Discussion 9 05-19-2011 01:56 PM
timing belt procedure - V6 BobES300 Camry & Solara Lounge 7 12-31-2004 05:20 PM
Question about allen wrench size for coolant plug c1tyhunter Archived Corolla threads 3 12-08-2003 11:59 AM
Oil Filter Wrench BenG Hardcore Tech and Competition 12 07-22-2003 10:01 PM
How to apply 200 ft lb torque w/ 150 ft lb max torq wrench? Corbett Archived Corolla threads 11 09-26-2002 04:07 PM
