Power Antenna out? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-04-2006, 02:34 PM   #1 (permalink)
View JOHZP's Photo Gallery
3rd Generation Power Antenna out?
Hey guys, I have a gen3 camry. 1992 Camry LE I-4.
Recently I bought a new antenna mast, and replaced the old one.
It was working fine until just the other day when I had to adjust some wires on my terminals so It would fit under the cap thing that covers it. Stupid me, I didn't unhook the negative charge, and tried to move the wires on the positive. I saw some sparks fly, but I didn't mind it. Now when I switch to radio mode, the antenna won't go up. I've tried most things, like reset my deck, and switch it to the original OEM one.
Everything else works fine in the car, including my subs, and amp. But when I switch to radio mode, I don't hear anything going up anymore. Did I fry it? Also there seems to be a fuse at the top of my trunk roof in the middle of both my midrange speakers. I took it out to replace it, but never got the time to get one and put it back in.
Can anyone help me? I really want to use my antenna. =(
Thanks
JOHZP is offline   Reply With Quote
Old 02-04-2006, 03:15 PM   #2 (permalink)
Anyone?
Old 02-05-2006, 12:26 PM   #3 (permalink)
Can anyone tell me how to test the motor to see if its the motor or something wrong with the signal not going to it?
Old 02-05-2006, 01:19 PM   #4 (permalink)
MCH Engineer in training
Location: A-town, Doylestown, & Northampton, PA; Morgantown, WV (WVU COE)
View ag6286's Photo Gallery
check the fuse, you probably blew it
ag6286 is offline   Reply With Quote
Old 02-05-2006, 02:53 PM   #5 (permalink)
Gangsta SC400 & 5.7Tundra
iTrader Score: 35 reviews
View -SCWEET1-'s Photo Gallery
Check the fuse, and I may have a antenna with the motor since mine got shaved....
-SCWEET1- is offline   Reply With Quote
Old 02-15-2006, 06:57 PM   #6 (permalink)
Should I be checking the fuse & relay box in the engine compartment, or just replace the blown fuse in the trunk.
It reads "stanley 12v12w"
Thanks
Old 02-18-2006, 03:40 AM   #7 (permalink)
It seems like it might be a bulb instead of a fuse. ANyone wanna correct me on this?
I tried autozone and pep boys, and they couldnt find a replacement fuse for it. Tried a 2aone and a 6a one, and they both blew.
Thanks
Old 06-21-2006, 04:33 PM   #8 (permalink)
Just took a look at the antenna again yesterday. Seems like no power is going to it.
Anyone want to help me locate the power antenna fuse?
Old 06-21-2006, 05:07 PM   #9 (permalink)
Also, what if the antenna goes down but not up?
Tried to replace the cig/radio fuse but didnt work.
Old 06-21-2006, 09:30 PM   #10 (permalink)
View toyomoho's Photo Gallery
There may be 3 fused power wires going to the motor. Cig/Radio(20A), ECU-1G(15A) and dome (20A). Check all your fuses as I may not have the exact ones listed. I think there is one fuse box in the engine compartment and one in back of the drivers side ash tray.
See what you find and post back.
Old 06-21-2006, 10:11 PM   #11 (permalink)
View FCBarca's Photo Gallery
3rd Generation
Just picked up a used 1993 Toyota Camry V6 LE and it has a faulty power antenna as well...It powers up and down but on the UP, it makes a lot of noise and sounds as if it's never going to fully extend.
Curious what would be involved in getting a replacement...Do I simply get a replacement motor or motor with mast etc.?
Thanks
FCBarca is offline   Reply With Quote
Old 06-21-2006, 10:50 PM   #12 (permalink)
Hey, thanks for the reply. I already checked all three of those fuses and replaced them. Does the fact that I have an aftermarket deck change anything? It did work before all this happened.
FCBarca: Yeah that was my problem before when it made noises. That means that your motor is fine but your mast is damaged or broken. Just order a new one online for around $16 like I did.
Old 06-22-2006, 12:23 AM   #13 (permalink)
I would say yes, this could be your problem. When a Toyota radio is switched on. It completes a circuit in the radio that activates relays in the antenna by means of the wiring harness. The antenna then goes up. Did the new radio come with control for a power antenna? Check the installation manual.
Old 06-22-2006, 12:05 PM   #14 (permalink)
Gameroom cash: $304255
Did you ever check the wires that you moved for fraying. The insulation may have been scraped off and you are shorting some wire to ground. If that is the case and you don't repair that you will simply blow any new fuse that you install. Check those wires and repair as necessary; then install a new fuse and try it.
Mike
Old 06-22-2006, 11:48 PM   #15 (permalink)
OK, I think ive tried everything, Im sadly coming to the conclusion that my antenna motor is dead.
How Would I Be Able To Get The Most Power Out Of My Amp? Vato Loco Audio, Video, and Security - Tech 6 10-26-2004 02:22 PM
Camry Radio Antenna psully Camry & Solara Lounge 7 09-21-2004 11:33 AM
Power Antenna dna59 Camry & Solara Lounge 7 08-19-2004 09:22 PM
2000 4runner power antenna fred g 4Runner Lounge 3 01-07-2004 03:42 PM
