Lowering Springs...Camber Kit - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-30-2002, 11:20 PM   #1 (permalink)
View lonis's Photo Gallery
If I am upgrading to 18" wheels, and getting Intrax lowering springs, 1.9 drop front, 1.8 drop rear, do i need a camber kit?? Tires.com e-mailed me back saying that I did with that much of a drop, I was just wondering if anyone else has gotten one, and if I need it, because they said its $70. Thanks.
Lonis
1998 Toyota Avalon XLS and yes... the 'S' stand for Supercharged
1/4 mile - 14.5
lonis is offline   Reply With Quote
Old 12-30-2002, 11:45 PM   #2 (permalink)
Luc
View Luc's Photo Gallery
Yes, you should get a camber kit with that much of a drop, otherwise, you'll be going through 18" tires very quickly. You might get away with not having a set in the rear, but for the front, definitely. Plus, your Avalon weighs more than a Camry, so you will need to correct the negative camber due to lowering.
Luc
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 12-31-2002, 12:00 AM   #3 (permalink)
DJModifyd
alex's Avatar
View alex's Photo Gallery
Luc
i have a 2.5" drop on my cam and i don't have any negative camber
most people think i paid a crap load for a camber kit, but its just good the way it is
alex is offline   Reply With Quote
Old 12-31-2002, 12:11 AM   #4 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $307175
Camrys (errr... Avalons...) don't need chamber correction nearly as much as Hondas (and most other imports) do. Most of the time it can be corrected with the toe adjustment bolts. Don't worry about it unless the alignment shop says they can't get the camber right.
-Charlie
Old 12-31-2002, 03:03 PM   #5 (permalink)
Luc
I only say yes b/c the '98 Avalon is based on the same chassis as the Gen4/Solara. Having seeing a friend with GC on his Solara without a camber kit, the inner sides of his front tires were balding at a faster pace than the rest of the rubber contact. Once he got the 1-degree camber bolts, the wear was even. It would still be a better investment of $35 than to go through 18" tires that are costly.
Luc
