Power windows not working - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-05-2006, 11:59 AM   #1 (permalink)
MCH Engineer in training
Location: A-town, Doylestown, & Northampton, PA; Morgantown, WV (WVU COE)
View ag6286's Photo Gallery
3rd Generation Power windows not working
1993 4-dr
so i get in my car the other night to go out to a party and its a nice night so i thought i'd roll down my windows....only they didnt roll down, passenger and both rear windows, driver side still works fine. Is it safe to assume this is a blown fuse somewhere?? most likely one under the steering wheel?
and im sure i could figure out the answer but its very cold out now so im trying not to spend an hour in frigid temps looking for a possible solution
ag6286 is offline   Reply With Quote
Old 02-05-2006, 01:57 PM   #2 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
I don't actually know if there is a fuse for this, but you need to pull your door panel off and check the units to see if they burnt out or anything
RichieRichJP is offline   Reply With Quote
Old 02-05-2006, 03:26 PM   #3 (permalink)
3 ofthem at the same time?
Old 02-05-2006, 04:45 PM   #4 (permalink)
Local Rape Machine
View ekim55121's Photo Gallery
make sure that the window lock is not on cuase that could also be your problem, if its on only the drivers side window will work none of the rest will work
ekim55121 is offline   Reply With Quote
Old 02-05-2006, 06:35 PM   #5 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
^ lol...that's what it actually sounds like....or if the button isn't down, they may be something wrong with the master unit making locking them
HaHa
Old 02-05-2006, 09:28 PM   #6 (permalink)
Local Rape Machine
happend to my mom when we first got our corolla and she flipped out on me cause i had washed the car and cleaned the interior earlier after she calmed down i pushed the button and she felt stupid, it was great the look on her face was price less
Old 02-05-2006, 10:44 PM   #7 (permalink)
The 73rd
Synwolf's Avatar
View Synwolf's Photo Gallery
I had my windows stuck down for the longest time. Completely undrivable come winter, and I couldn't take it into the city to get it fixed either.
Synwolf is offline   Reply With Quote
Old 02-06-2006, 01:38 AM   #8 (permalink)
TN Pussy Man
^ if that happens, take your door apart and then manually move the window up the track, block it off, and then just don't use it until you get around to fixing it
HaHa
Old 02-06-2006, 02:51 PM   #9 (permalink)
.....sigh...thats probably the problem....never even occured to me.... , ill go check that one out abit later
while were on the topic of windows, my passenger side window broke off teh track a few months back...i find it almost impossible to get the door handle cover piece off (interior)...anyone else run into this problem/any suggestions..i feel as though im gonna break it like my brother did the passenger side one
Old 02-06-2006, 03:20 PM   #10 (permalink)
Dealer Tech..not Toyota
Axel Kain's Avatar
View Axel Kain's Photo Gallery
well, i can relate, where the "hinge" is for the latch and lock, put a tiny flat blade screwdriver in (theres a bit of a grove on the bottom part(under handle)) and put some pressure down on that, then do the same on the top, just push up, and jiggle/ pull straight at yourself on the edege your working with. just be careful not to put tooo much pressure on those releases or it may crack.
oh and once the back is free, slide it back (towards the latch, hold the latch in the open position) and it should come right out...once you get it out its easy to see how it works, for future reference.
good luck
Quote-Terrastrife: Axel the confusion specialist!
-1992 Camry V6 XLE- *3VZ-FE* (with a dead auto trans.) <SOLD!
Newest addition- 1987 300zx Turbo! what a blast!
Axel Kain is offline   Reply With Quote
Old 02-07-2006, 10:27 PM   #11 (permalink)
Pabloso
project92camry's Avatar
View project92camry's Photo Gallery
Off Topic
Im Having A Problem With The Drive Side Window Button.. Should I Change The Whole Unit Or Just The Button?? And Where Can I Get The Master Unit Cuz I Know Its Hard To Find A New Oem One
project92camry is offline   Reply With Quote
Old 02-07-2006, 11:13 PM   #12 (permalink)
TN Pussy Man
^ take it apart and see if it's fixable first
sometimes it can just be oxidation on the contacts and can be cleaned off
what happened with mine was a bit weirder- the window would only work when I pulled up on the tab REALLY hard, so after I took the unit apart, I cut off the little tabs on the back of the driver's window switch (when you take it apart and look at it, you'll see what I mean) so that there can be better contact, and now it works like it always has
and if you just want to get a new one, go on ebay and you can find new ones for pretty cheap actually- it's just unfortunate that they won't ship to canada for us canadians
HaHa
Old 02-07-2006, 11:41 PM   #13 (permalink)
Pabloso
Thats Exactly Wat Happend To Mind.. Its Stuck And I Got To Pull It Hard .. It Sux , But Im Gonna Try Wat U Said.
Old 02-08-2006, 03:25 PM   #14 (permalink)
TN Pussy Man
here's where the tabs to cut off are/were:
hope that helps
HaHa
Old 04-05-2006, 10:47 PM   #15 (permalink)
View 94camrykid's Photo Gallery
Hey guys/gals,
Sorry for bringing up a dead thread...
Eye8pussies - Do you remember how to take off the cover off the switches?? I have this same problem where i have to pull really hard on the driver's side window switch for it to go up, and just recently had it stop being able to go down. I know it still wants to go up because I can see my gauge cluster lites dim a tiny bit. (no dimming when it is switched to go "down") I took it out tonite and i wasnt too sure how to disassemble it to clean the contacts..I saw some screws and tabs that I tried to undo, but no luck..Does the Covering just snap off?? I'm not too mechanical and I have a tendency to break things by accident when I'm trying to fix them lol..Thanks for any help you can provide...
A
94camrykid is offline   Reply With Quote
Power Windows roll up slow JohnCWms27 Camry & Solara Lounge 10 07-09-2004 12:08 AM
HELP! door locks and power windows died hans747 Audio, Video, and Security - Tech 1 11-11-2002 11:50 PM
