Windscreen is squeaking when wipers on - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-05-2006, 10:25 PM   #1 (permalink)
View breezey's Photo Gallery
My windscreen is squeaking when I put my wipers on. It doesn't matter how much water (rain ) falling onto.
The car is Camry Altise (Aussie) late 2004. It is still under new car warranty and I have mentioned this problem to the Toyota mechanic when I was doing maintenance service and I was told that Toyota's windscreen is coated with some sort of film when it is out from the factory and when the film is somehow wearing away it will cause the noise when wipers are on. Unfortunately I was also told that Toyota has not come up yet with a solution. I hardly could believe that. Is it really because of the film coating that is wearing out?
Is there anyone here ever experienced the same problem? Please share if you know something that may solve my problem. I check the wiper itself and they are fine.
Thanks.
breezey is offline   Reply With Quote
Old 02-05-2006, 11:15 PM   #2 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
I don't think your problem is limited to your model. Every Toyota I've had gave this problem at one point or another, and I've found that the semi-metallic wiper blades cause the problem. Try shopping-around for another type of wiper blade, it may just fix your problem.
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 02-06-2006, 07:09 AM   #3 (permalink)
The 6"4 Viking
Zandro's Avatar
View Zandro's Photo Gallery
Get Denso viper blades solved the same problem for me, i used bosch viper
blades before and they where realy noisy hell!
Zandro is offline   Reply With Quote
Old 02-06-2006, 08:01 AM   #4 (permalink)
Thanks for your replies. It is good to hear that it is unlikely the windscreen itself that causes the problem. In this case, I suppose you won't suggest me to get a pair of original wipers from Toyota then. Wondering why they make such a troublesome wipers?
If there is anyone else has different opinion or experiences I would like to hear. Otherwise I will shop around for wipers blade then.
Thanks a lot.
Old 02-06-2006, 02:11 PM   #5 (permalink)
Bullitprooph
Like Zandro said, get Denso blades. Denso makes a lot of parts for Toyota (I think they may be a subsidiary of Toyota, actually), and they're all top-notch. My guess is the blades your car came with were bottom-of-the-line to save the dealership $$.
Old 02-06-2006, 02:40 PM   #6 (permalink)
Gameroom cash: $304255
If the rubber inserts themselves are not ripped, before doing anything else, wipe down the rubber inserts with a paper towel or cloth soaked in alcohol or even windshield washer fluid. Alcohol works best. Chances are the inserts are just dirty and soaked with oil from the rode grime that gets tossed up by vehicles in front of you when you are driving in the rain. I know this sounds silly but give it a try.
Mike
Old 02-06-2006, 05:28 PM   #7 (permalink)
rusty9's Avatar
Gameroom cash: $441505
View rusty9's Photo Gallery
the chattering and sqeaking is caused by the wipers getting a permanent bend in them being in the off position. since the windshield is curved, the bends in the wipers dont match the curve of the windshield when they swipe across. get new inserts.
rusty9 is offline   Reply With Quote
Old 02-06-2006, 05:51 PM   #8 (permalink)
Iron Chef IV
View drunken_panda's Photo Gallery
Could also be a dirty windsheild. Use some window cleaner and clean the glass, you will be suprised at how dirty the towel gets.
drunken_panda is offline   Reply With Quote
Old 02-08-2006, 02:18 PM   #9 (permalink)
I have tried to clean the windscreen but it wouldn't solve the problem. I will try to clean the wiper with alcohol or otherwise I think I will buy a Denso blade.
Someone suggested to use car wax to clean my windscreen? Won't that do any harm to the windscreen?
Old 02-08-2006, 03:36 PM   #10 (permalink)
Moving Forward
View Cyorke's Photo Gallery
in my experience the best wipers to put on Toyotas are Toyota replacements. WHen I was at the dealer I worked for we had people coming constantly complaining of wiper noise. We would either put new inserts in or have to replace hte entire blade if they had aftermarket. After doing this they did not have any problems with them until time to replace again. Normally you will need to replace your wipers about twice a year depending on weather conditions in your area. I know here in Middle Tennessee that is the case anyway.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 02-08-2006, 11:36 PM   #11 (permalink)
Bullitprooph
2nd Generation
You could do the wax thing, but it has two drawbacks: 1) At highway speed the blades tend to lift off the glass more easily, causing chattering; 2) The blades seem to deteriorate more quickly.
I use RainX brand fluid, works like a charm (and seems to extend the life of my wiper blades, too--120,000km on this set so far).
Old 02-08-2006, 11:50 PM   #12 (permalink)
1993 Camry XLE
HoboJoe's Avatar
View HoboJoe's Photo Gallery
I got my wiper blades at wal mart and... they work great.
HoboJoe is offline   Reply With Quote
squeak!!? or what could it be? rice Archived Corolla threads 7 02-06-2006 09:39 PM
winter wipers elvasoshexai General Discussion 3 10-30-2005 12:22 AM
windshield wipers elvasoshexai General Discussion 8 11-17-2004 10:58 PM
93 LE Wagon rear wipers lugnut 3rd & 4th Generation (1992–1996 & 1997–2001) 3 09-26-2004 05:59 PM
problem with wipers (gen3) undrcroft 3rd & 4th Generation (1992–1996 & 1997–2001) 0 09-07-2003 11:05 PM
