Hi all,
I've got a '91 Camry 3S-FE with 267,000km (165K miles) on the clock which has recently been creating its own weather system behind me when I drive to the point where an EPA warning was issued (the Environmental Protection Authority here in Australia).
I'm no mechanic, but from what I've been told it's probably due to a head gasket or valve problem... whatever it is the top end needs to come off, and since I don't really need the car or intend to keep it, I don't want to spend big bucks fixing it. I performed a compression test on it but it didn't reveal any major/obvious problems. Cylinder 3 has got worn rings and cylinders 1 & 3 have excess oil. It's not really burning oil and the coolant (which actually looks like rusty water!) doesn't seem to ever run low, but there are a number of other oil leaks/sweats around the head, and there's probably other things wrong which would make it unlikely I'd be able to get a roadworthy certificate to sell it privately even if I get the head fixed.
Anyway, back to my question: is there any quick/cheap way to temorarily fix the white smoke (mainly when the engine's at operating temp) long enough to get it traded in for a new car (corolla hatch)?
Any advice will be greatly appreciated, otherwise the camry is headed for the wreckers
, and I really would like to avoid that because it's served us well and can be fixed by someone who is willing to put in a little $$ to do it.
Thanks.
