Multiple Timing Marks on Camshaft Gears - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-06-2006, 09:05 PM   #1 (permalink)
View Zanteus's Photo Gallery
Question Multiple Timing Marks on Camshaft Gears
I recently had to replace the water pump, so I figured while I was at it I would go ahead and replace all drive belst including the timing belt and the plugs and wires. On my initial investigation, I found 2 marks scribed in the left hand camshaft gear, and one scribed mark on the right hand gear. On the left hand gear the is a scribed mark just to the right of one of the spokes marked 3V, the next spoke over there is a scribed mark in the middle of the spoke and it is marked 4V, I for the life of me cxan not get this thing in time. I verified TDC and that the distributor rotor qas pointing to the number on cylinder. The engine will start, but it runs erratically and will not idle. Does anyone have any suggestions? I am all out of ideas.
Thank you very much.
Z
1992 Toyota Camry XLE V6 Japanese Model
Zanteus is offline   Reply With Quote
Old 02-07-2006, 03:47 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Download and read:
http://www.**********s.com/camry
"Skoolin' the unlearned!"
Old 02-07-2006, 03:59 AM   #3 (permalink)
Question
Thanks for the input but that doesnt address the fact that on the left hand camshaft gear there are 2 marks, one marked "3V" the other marked "4V", and on the right hand gear there is only one mark. Which one of the marks do you set it too?
Old 02-07-2006, 04:14 AM   #4 (permalink)
Grenaded piston
88 LE's Avatar
http://autozone.com/servlet/UiBroker...3d8013e607.jsp
^ Look under 2VZ-FE and 3VZ-FE engines. You have a 3VZ-FE.
Step 13 says this:
Set the No. 1 cylinder to TDC again. Turn the right camshaft until the knock pin hole is aligned with the timing mark on the No. 3 belt cover. Turn the left pulley until the marks on the pulley are aligned with the mark on the No. 3 timing cover.
So there should be a mark on the pulley (cam gear). And a mark on the timing belt cover.
Something like this:
http://autozone.com/images/cds/gif/m...3d8013e611.gif
Notice the notch on the timing belt cover (marked with white paint in the pic below):
http://autozone.com/images/cds/gif/m...3d8013e612.gif
Notice the marks on the pulleys, their right above the notch for the knock pin:
http://autozone.com/images/cds/gif/m...3d8013e618.gif
Old 02-07-2006, 05:47 AM   #5 (permalink)
I totally understand what you are saying, but there are 2 marks on the left hand gear, one marked 3V the other marked 4V, which do i line up to the timing cover is my question
Old 02-07-2006, 07:08 AM   #6 (permalink)
Grenaded piston
88 LE's Avatar
http://autozone.com/images/cds/gif/m...3d8013e60a.gif
^ Pic above shows a 3V marking, but its lined up to a mark on the timing belt, not the timing belt cover.
Can you take a pic of the camgear in question and post it up?
timing belt replaced, now 5 deg atdc?? asm Camry & Solara Lounge 5 07-20-2005 04:22 AM
QUICK SHIFTER/UNDER PANEL PROBLEM!! & DVD NAVIGATION??!! Rocness81 1st Generation (2003-2008) 6 12-09-2004 10:27 AM
87 Corolla hesitation problem. Bad_dude Archived Corolla threads 8 10-25-2004 04:31 PM
94 corolla electrical problem al_sniperrolla Archived Corolla threads 0 10-16-2004 10:42 AM
Motor Mount problem and other, please help lazycat Camry & Solara Lounge 4 08-16-2004 09:32 PM
