um....two hid kits eh? dude you should first read about the HID system first before you do that. check the voltage spike when a hid system starts, its near double that of a regular bulb, and around 15-17v I think. Adding to this for a hid bulb to completely turn on, it takes about 10secs for the salts to burn, so using them as high beams and is not useful, not to mention it will kill the life of your bulb, and just your electrical system a test of their strength. To this you'll also need a GOOD hid harmness AND relay! the harness that comes with most aftermarkey kits suck period. Make you own, its easy. Good luck but IMHO I think its a bad idea, might as well put HID in the fogs too!
