Need Help regarding my Brakes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-01-2003, 08:36 PM   #1 (permalink)
View danny67x's Photo Gallery
Hey guys,
I need to replace my brake pads i'm pretty sure. I've noticed when I brake, the car tends to shake a little, and i've had the car for around 60,000 miles without changing brakes.
I have a 98 4 cylinder camry, how would I go about replacing my brakes, and what brake pads do you guys recommend? I've heard that the TRD pads get a lot of dust, the factory brake pads should be fine?
Danny
danny67x is offline   Reply With Quote
Old 01-01-2003, 10:08 PM   #2 (permalink)
Man on a mission...
View SKYravefever's Photo Gallery
Yeah
OEM pads should be sufficient.
SKYravefever is offline   Reply With Quote
Old 01-01-2003, 11:28 PM   #3 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
Agree with Sky'. Get your rotors checked to see if they are the cause of that shaking you're experiencing
Phi is offline   Reply With Quote
Old 01-02-2003, 01:02 AM   #4 (permalink)
View tinman831's Photo Gallery
I noticed the same shaking problem on my sisters camry. The dealer said that the rotors were a little warped and that was causing the shaking. He said it was common (?) in camrys. I also notice the same problem in my camry as well. :x
tinman831 is offline   Reply With Quote
Old 01-02-2003, 12:11 PM   #5 (permalink)
i also have 18 inch wheels and a coilover setup. do you think oem pads would still be sufficient?
Old 01-02-2003, 12:55 PM   #6 (permalink)
View Deep's Photo Gallery
EBC pads are nice and they don't give off much dust at all. OEM pads are cool for regular driving but if you drive a little harder than the majority then step up to some quality aftermarket pads. If your rotors are a little warped then you can have them machined, if they're very warped then you gotta replace them.
Deep is offline   Reply With Quote
Old 01-02-2003, 03:14 PM   #7 (permalink)
ryan7373's Avatar
View ryan7373's Photo Gallery
The best pads I've ever had on my car have been ceramic... no dust, they last longer, and quiet.
'98 CAMRY LE I-4
-is300 wheels [FOR SALE in HOUSTON]
ryan7373 is offline   Reply With Quote
Old 01-02-2003, 03:48 PM   #8 (permalink)
View cdnsupra's Photo Gallery
KVR and Porterfields have little dust for keeping your 18's clean, but they are also expensive. The porters are on the order of 100US for front and rear pads.
i agree with the others that shaking brakes usually points to a warped rotor. driving through a big puddle after using your brakes is all it takes to warp them some times.
Ben
CdnSupra from Hamilton
91T, stage 3+[87T has been retired]
cdnsupra is offline   Reply With Quote
Old 01-02-2003, 06:42 PM   #9 (permalink)
ryan7373's Avatar
It's not too bad if you can do it yourself or you know someone. I had a friend help me put the pads on then went and got my rotors shaved. Pads were around $70 and the brake place charged me like $40. Not too bad. And like I said they're the best pads I've ever tried. I had OEM ones put on when I first got the car and they made soo much noise I changed them after one month.
'98 CAMRY LE I-4
