My wifes 2002 Camry 1MZ-FE just started haveing probelms this morning. I had it towed to the dealer and the computer told them that the Mass AiR Flow Sensor was on its way out. So here is my question: Where is it located and is it easily accessible to me? I am guessing it has to be somewhere between the air filter and the throttle-body?
Jason
94' Camry XLE, Tan Leather, 1mz-fe, 173,000 miles
02' Camry SE, Black Leather, V6, 92,000 miles Peak Performance
you got it. it's that thing that has the wires plugged into it. that needs to be replaced. but funy thing is that i have a 94 130kmiles and it's still running strong with the original.
The car above 40mph would shudder a bit like it was starving for something. Then die. My 94' is still running strong as well. I looked at an 2003 today to try and find the location of the sensor and there was a few things on that air duct between the filter housing and the throttle body. The first one closest to the filter housing on the 2003 that I looked at today had part# TN197400-2040? If that is the part number then it is the same location as our 94's right there up against the filter houseing. Any idea which one it was? Is it in the identical location as our 94' Camry's? Bad thing is, its at the dealer now and I am wondering what they are going to charge me for hooking up the computer if I do not want them to fix it? And how safe would it be for me to limp home with it?
Jason
Either way I am probably still going to be out something for the dealer running the scan, correct? But can I limp to autozone and have them do what you suggested? Now that I think about it, since I will probably owe the dealer something for running the scan, I can just have them reset it, couldn't I?
You can limp it home and you shouldnt ahve any major problems.
As for location it is where you are thinking it is. IT is normally closer to the air box than the throttle body. If you remove the tube from the airbox and look in you will be able to see it on the inside.
As for what the dealer is goig to charge you it will probably be anywhere from a half hour to hour worth of labor. When I was a tech that was normal. Half hour for jsut doing quick diagnostic type stuff an hour for more mechanical diagnosis type stuff, engine noises, tranny problems and things like that. If they try to get you for more than an hour worth of labor then you need to tell them to shove it and find out why they want more than that. It takes about 5 minutes to plug in the OBD2 and read codes.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
btw, the stealership will probably charge you the fee of reading it through the scanner. which is like $40. when you could've done it free at autozone.........you can also order the maf sensor at autozone or discount auto parts.
my sister has her sensors running haywire too. She got the "engine running lean". 2 years ago the stealership did supposedly "change" or fix the sensor under warranty.......but it's broke again and now no warranty. =/
-Custom 2.5in Cat-back Exhaust + Borla Muffler + Weapon R Dragon Intake + TRD Rear Sway Bar + TRD Springs + TRD Front Strut Brace
Now I know about autozone........First time I have run into anything like this. Dealership has the same price as autozone for the sensor. That is for a brand new one not an Cardone remanufactured. To many bad dealings with Cardone or A-1 Cardone. So do you think they will charge more than the $40 for reading the code if I ask them to clear it?
Jason
yeah, if you ask them to fix the code..........that's something else.
What they'll end up doing is charging you for the Maf sensor, then charge you for the labor to install it. Whereas, you could go to autozone, have them order it, and install it yourself.
They're gonna charge you $40 anyway for reading the code. just because your car is there with a check engine light. but you gott agive them the ok to fix it usually.
Seems lke you are asking us questions that you should have asked the dealer first! If OEM is the same price as AZ then I would go OEM. Whether you install it or not is up to you. One thing to remember if the dealer installs it after diagnosing it and it doesn't fix the problem you have some recourse. Whereas if you put it in you probably do not have any!
Gary
Don't worry about what other people think....as most of them don't!
One other thing to think about is most of the time if you ahve hte dealer install the part you dont pay much extra for the labor. THey may charge you jsut the half hour since it takes about ten minutes to put the MAF on or they may jsut charge you a full hour worth of labor. Gary makes a good point also. IF the MAF doesnt fix it then it is the dealerships responsibility to diagnose farther. If you do it yourself and it doesnt fix it then you are out the part plus you still need to figure out what is wrong.
Another thing is the codes that they pull out of the ECU are not the end all be all of diagnostics. Just because it says a certain part has failed or is not operating within specs sometimes there can be underlying factors as to why it is that way. THere could be another part that operates in conjunction with the MAF that has caused the MAF to malfunction. If that makes any sense.
Chris
The reason I was asking so many questions was I only had a short conversation with the dealer yesterday. I did not have time yesterday to deal with them. That is the reason all of the questions to you all yesterday. So.......Now here is what happened today. Service advisor calls me and tells me "they tried cleaning the MAF sensor and it did not help." I said "I quess you did it for free because I did not authorize it........She said "I am sorry, I thought you did, ok no charge." Another tech look at it and there were two codes thrown (1st tech failed to tell advisor that there were two thrown). The second one was "#6 Cylinder Misfire." Resolution: Replace per TSB EG008-04. If you are within your 3/36 month warranty, no charge. Well we have 49K on the odometer. So the extended warranty covered it after my $100 deductible. Changed the coil, no more codes at all. Keeping it over night again, supposed to be low 30's in the morning and want to check it when it is cold.
Jason
