LF: fog light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-08-2006, 06:03 AM   #1 (permalink)
View Quincy's Photo Gallery
Gen5 LF: fog light
Shopping for a set of fog light for my 02 Camry LE.
All of you have purchased fog lights for gen5, which seller and/or product give you the most satisfactory?
Thanks.
Quincy is offline   Reply With Quote
Old 02-08-2006, 07:16 AM   #2 (permalink)
Midship Captain
ModifierMR's Avatar
Gameroom cash: $344471
View ModifierMR's Photo Gallery
Alot of people get kits off ebay for around $30-50, i do not know which seller is the best but thats where they get them.
Make sure that your camry front bumper supports fog lights. My Bumper has the Indentations. On some camry's the hole will just pop out. My camry does not. I need to cut the actual hole.
すべての日本への私のお悔やみ。
ModifierMR is offline   Reply With Quote
Old 02-08-2006, 09:17 AM   #3 (permalink)
Iron Chef IV
View drunken_panda's Photo Gallery
After you cut the hole though, it fit with no problem?
drunken_panda is offline   Reply With Quote
Old 02-08-2006, 10:05 AM   #4 (permalink)
Midship Captain
ModifierMR's Avatar
Well ive never installed them so i dont know if it requires more mounting hardware scince the bumper was never prepared for them to begin with.
すべての日本への私のお悔やみ。
Old 02-08-2006, 10:08 AM   #5 (permalink)
HID/Retrofit Expert
white3ch0c0late's Avatar
iTrader Score: 7 reviews
View white3ch0c0late's Photo Gallery
If the holes pop out, it mounts right in. I got my kit off of "k2motor" on ebay. Fast shipping, and no problems. Comes with all the lamps, wires, relays, and switches that you need to get up and running if you aren't pre-wired. (All I needed was the lamps themselves and a new OEM turn signal stalk since I was pre-wired).
If you cut the hole, you will PROBABLY need to put in some sort of mounting bracket.
2009 Audi TT 2.0T --- THE BEAST!
2002 LE 4Cyl --- Gone, but not forgotten. 06/28/09
Glaring blue HID bulbs are NOT classy, and don't make your car look nice, no matter what that kid in the Civic told you.
white3ch0c0late is offline   Reply With Quote
Old 02-08-2006, 03:21 PM   #6 (permalink)
Thanks for the replies so far.
The covers on mine pop out, so i don't have to cut the bumper.
I am looking for honest/good seller.
Old 11-06-2008, 04:30 PM   #7 (permalink)
View viewfinder11's Photo Gallery
aftermarket fog lights - relay
hello. i bought a set of foglights from kragen, its about 20bucks it came with lights, mounting hardwares, and harness, i noticed that the (power - wire) came with built-in fuse with it, and also it come with a relay. the installation did not mention anything about a relay for installation. so im just wondering if i would need a relay, and is it necessary to have with the foglights installed? can i also get a separate relay? and would it be okay to use a set of foglights without a relay? thanks..
viewfinder11 is offline   Reply With Quote
05 Fog Light retrofit Activator 2nd Generation (2005+) 18 01-26-2007 09:04 PM
Aftermarket FOG LIGHT SWITCH WIRING PROBLEM...2002 Tundra SR5 garzee13 1st Generation (2000–2006) 3 11-24-2005 05:58 AM
04 Fog Light Replacement echosierra Archived Corolla threads 0 09-27-2005 12:12 AM
