Adjusrtment shift cables Manual 4 cyl - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-08-2006, 06:59 PM   #1 (permalink)
97 Camry
View Davee's Photo Gallery
4th Generation Adjusrtment shift cables Manual 4 cyl
Ever since new my 97 LE 4 cyl 5 spd manual has been trouble picking reverse . Dealer says nothing wrong( BS!) Anyone know the set up technique to improve shifting to reverse? Chilton manual is useless -- "installation of cables --"Reverse of removal"" I assume one of the cables has to pull more or push more ??
Incidentally this winter synthetic oil in Tranny has helped cold weather shifting tremendously
Davee is offline   Reply With Quote
Old 02-08-2006, 10:42 PM   #2 (permalink)
Cressida nut
Gameroom cash: $248745
View kamesama980's Photo Gallery
its not the cables, reverse is pesky in all manual trannys because its not always engaged and changing gears just does up the synchro. forward gears are bevel cut (at an angle like ///////////) and are always engaged. changing gears engages a mini-clutch type device to match speeds then the teeth engage the shaft to the spinning gear. reverese is straight cut gear (like |||||||||||||) that actually engages and disengages when you change gears. theres absolutely nothing you can do about that aside from getting an automatic. thats also why its a bad idea to engage reverse while the car is moving, esp forward. for the basics, read www.howstuffworks.com 's article on manual trannys
'90 Cressida, 7M-GE, M5 (2JZGE-T coming)
'91 Toyota Pickup, 22R-E, M5
'90 Suzuki VX800
"You don't get to judge me for how I fix what you break"
kamesama980 is offline   Reply With Quote
Old 02-09-2006, 07:02 PM   #3 (permalink)
97 Camry
I know about synchros! The problem persists in spite of Moving a bit in forward -to better line up the straight gears. I still think cable adjustment could help
Old 02-09-2006, 08:28 PM   #4 (permalink)
View Gary_602Z's Photo Gallery
What is it doing? Grinding,popping out or not engageing?
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 02-11-2006, 01:41 PM   #5 (permalink)
97 Camry
Clutch & reverse
Gary
It does not engage so if clutch engaged it grinds Never popped out Feels like lever has not travelled far enough which makes me think one or other of ther cables could help
Old 02-11-2006, 10:52 PM   #6 (permalink)
Insert Custom User Title
BigPete's Avatar
View BigPete's Photo Gallery
My car does the same thing, only thing that I've found that solves it is to take my foot off of the clutch pedal, and try again. I don't think that theres anything wrong, it's just kinda annoying.
BigPete is offline   Reply With Quote
'05 Toyota Avalon Manual Shift Mode jimmykce1 3rd Generation (2005-2012) 12 05-02-2005 10:51 AM
manual conversion Ultima Camry & Solara Lounge 12 03-25-2005 05:37 AM
1999 Tacoma - Manual Locking Hubs or Shift on the Fly? trailrunners 1st Generation (1995.5–2004) 3 02-26-2005 12:08 PM
Code 51 88 Camry 4 cyl manual / A/C 1812 1st & 2nd Generation (1983–1986 & 1987-1991) 1 08-22-2004 09:03 PM
