If a valve were stuck open youd know it
sounds like you need to look at your ignition timing, if the ignition timing is retarded enough the fuel mixture will still be burning when the exhaust valves open and it will burn in your exhaust causing it to glow red, if the timing is way way off look at your timing belt too.. that is if you have a distributor though heh
