can someone help me out ? my trunk light isn't working - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-10-2006, 04:00 PM   #1 (permalink)
View AyzhenInvasion's Photo Gallery
4th Generation can someone help me out ? my trunk light isn't working
so when i open my trunk, the light comes on, but today, i cut the plug off to the light and stuck it on my cold cathodes. they didn't light up. i tested the wires and it showed no voltage going thru ??
my cathodes work when i hook them up to the other 12v lights but not the trunk one ? are my wires bad, fuse blown ? does it share fuses with any other thing ? if not maybe its the fuse...
AyzhenInvasion is offline   Reply With Quote
Old 02-10-2006, 04:57 PM   #2 (permalink)
View keithy's Photo Gallery
The polarity of the cathod inverter is very sensative. Did you reverse the polarity of the inverter when you put it in? Coz, this can permanently damage the inverter and thus, the cathods will not light up. Try putting another power source on the cathod and make sure if it works.
keithy is offline   Reply With Quote
Old 02-10-2006, 07:35 PM   #3 (permalink)
yeah i tried both ways. no luck.
no voltage thru trunk light, no dome light, no clock... no power lock... didn't try power window.. AGH everything else seems to work. so did i blow a fuse ?
Old 02-10-2006, 08:22 PM   #4 (permalink)
Iron Chef IV
View drunken_panda's Photo Gallery
Yep. The some and clock are all on the same circut. Pull DOME and i bet it will be blown.
drunken_panda is offline   Reply With Quote
Old 02-11-2006, 11:51 AM   #5 (permalink)
0111010010
SnakeyeS's Avatar
View SnakeyeS's Photo Gallery
did you cut the plug off with the battery still hooked up??
"Knowing is half the battle."
Color Valentine One Displays
SnakeyeS is offline   Reply With Quote
Old 02-11-2006, 12:13 PM   #6 (permalink)
yeah i did, haha yeah i'm stupid i know. it shorted and i replaced the fuse. so its all good now.. next time = unplug battery lol
What is it? Trunk light? bowen Camry & Solara Lounge 8 07-19-2005 05:19 PM
Airbag warning light not working wrustless Camry & Solara Lounge 2 03-13-2005 11:09 PM
gen2 brake light stays on... help... please.. busted_ride 1st & 2nd Generation (1983–1986 & 1987-1991) 2 09-24-2004 04:56 AM
Interior Dash Light Not working,, Need HElp !!! DC Power Supra Forum 4 09-20-2004 11:03 PM
Trunk Light Help Please! cheeba Camry & Solara Lounge 11 03-03-2004 12:44 AM
