leakage...:( - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-10-2006, 05:55 PM   #1 (permalink)
greekin'8ez
View koloteamr's Photo Gallery
2nd Generation leakage...:(
i got 2 problems..my car has been leakin oil i poured ultra vilolet oil in like a cup worth into my engine to see where its coming from. well i found it, in 2 different spots. the valve cover gasket is leaking and im pretty sure the distributor is leakin too. any ideas on what i should do about getting theese parts and installing them and what exactly to buy? thanks guys...
There is nothin better than the rush of a DRIFT....
koloteamr is offline   Reply With Quote
Old 02-10-2006, 06:09 PM   #2 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Well, the obvious this would be to buy a valve cover gasket and a distributor o-ring/seal. Then remove the valve cover gasket and distributor, replace the gaskets and then put them back in...
JetspeedCamry is offline   Reply With Quote
Old 02-10-2006, 07:00 PM   #3 (permalink)
Moving Forward
View Cyorke's Photo Gallery
^^^^ what he said should pretty much take care of it. THose are fairly common leaking points on the four cylinder engines in Camry's and Celica's. Well pretty much anything with a 3S or 5S engine it it.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 02-11-2006, 04:10 AM   #4 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
2nd Generation
^^ The 2VZs and 4AGEs are also bad for valve cover/distributor o-ring leakage. Both are easy to replace, you don't have to dismantle too much to get them out. The rear bank valve cover removal on a &*%# transverse V6, however, is not so damn easy...luckily you have a nice, easy four-banger.
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
1998 Prius Transmission Oil Leakage hannah Prius Forum 3 12-10-2005 02:13 PM
Gas line leakage?!! GeRm0MR2 MR2 Forum 1 10-25-2005 07:45 PM
Wierd Coolant Leakage Calvin327 Camry & Solara Lounge 6 04-19-2005 11:28 PM
mkII boost leakage? ryde MR2 Forum 9 07-27-2004 12:03 PM
BOOST LEAKAGE IN MR2...please help ryde Hardcore Tech and Competition 2 07-22-2004 02:28 AM
