New Head Unit only gets power when lights are on - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-11-2006, 07:31 AM   #1 (permalink)
View nuggin's Photo Gallery
3rd Generation New Head Unit only gets power when lights are on
I just installed a new headunit.
I didn't use a harness, but dis get all the wires right.
however, the headunit only ever recieves power when i turn my headlights on
i can even take out my key, turn the headlights on and play music
i'm really confused about it
can anyone solve my problem
nuggin is offline   Reply With Quote
Old 02-11-2006, 07:48 AM   #2 (permalink)
View .tony. .riot.'s Photo Gallery
Apparently you didn't get all the wires correctly.
.tony. .riot. is offline   Reply With Quote
Old 02-11-2006, 08:07 AM   #3 (permalink)
Import Fire Fighter
View theMANry's Photo Gallery
you deffinatly have the wires that make it light up at night hooked up to the main power. and vise versa
2008 Scion xB 5spd
AEM CAI - TRD Exhaust w/o Second cat -
-TRD 19's - Eibach Sportlines -
many other goodies
theMANry is offline   Reply With Quote
Old 02-11-2006, 08:08 AM   #4 (permalink)
View digger08's Photo Gallery
There is two positive power wires usually to be connected.
One is a trigger wire, the other is constatnt power.
It sounds like one of these is connected to the headlight switch.
Trace your positive power wires and find a new, constant power wire and switched power wire.
Using a small multi-meter will help you identify if a wire is constantly supplying power.
Digger08
Digger08
Lexus IS300
01' Onyx/ Arm Rest/ 02 Tails/ Xpel/ Carson Tuned/ Eibach/ Ltuned 18's/ Injen Intake
GReddy EVO/ TeCk grounding kit/FigProprod/DashTray/ LSD/Ltuned Sways
digger08 is offline   Reply With Quote
Old 02-11-2006, 08:21 AM   #5 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Yeah well it's pretty obvious what the problem is...youve connected your LIGHTS/ILLUM wire to the HU +12V ACC wire. Just find the correct Accessory wire from your key or something (the old HU shouldve had a ACC connection) or if not use the Cig lighter or something and connect it to the HU's +12V ACC wire...
JetspeedCamry is offline   Reply With Quote
Old 02-11-2006, 01:06 PM   #6 (permalink)
one of a kind
View 96camryracer's Photo Gallery
You talk about hooking wires to wires and not using an harness.. why is that...spending $7-$20 on harness is not bad at all..plus its get the jobs done easier..(plug and play). Unless someone or you cut off the stock harness
Also you dont have to waste time finding which wires is what thus can cause your fues to blow.
i got my harness at wal-mart for $7.00 and it took me 10 min to hook my deck in.
96camryracer is offline   Reply With Quote
Old 02-11-2006, 01:17 PM   #7 (permalink)
Dealer Tech..not Toyota
Axel Kain's Avatar
View Axel Kain's Photo Gallery
true, but it save space by hardwiring it, also keeps things simpler in the long run. (like for an amp, better speakers+new speaker wire, etc.)
Quote-Terrastrife: Axel the confusion specialist!
-1992 Camry V6 XLE- *3VZ-FE* (with a dead auto trans.) <SOLD!
Newest addition- 1987 300zx Turbo! what a blast!
Axel Kain is offline   Reply With Quote
Old 02-11-2006, 01:18 PM   #8 (permalink)
TN's Nikon Expert?
prnc_chrmng's Avatar
Gameroom cash: $491868
View prnc_chrmng's Photo Gallery
the mans correct, its probly your red, wire from your stero harness thats hookd up to the headlights, ya need to find which wire gets power when you have your ACC on.
Originally Posted by 98tercel_girlie
This thread needs more porn, less blah blah
prnc_chrmng is offline   Reply With Quote
Old 02-11-2006, 01:26 PM   #9 (permalink)
Axel Kain's Avatar
^continuity testor...AKA, the clear ice pick with a light bulb, and a ground wire...lol
Scion Head Unit on ’98 Camry gmuri002 Audio, Video, and Security - Tech 7 01-24-2005 05:14 AM
Scion Head Unit on ’98 Camry gmuri002 3rd & 4th Generation (1992–1996 & 1997–2001) 3 01-23-2005 11:03 PM
Making some cool power (caution! For reference use only ) AngryAE101 Archived Corolla threads 5 11-03-2003 10:03 PM
head unit install corolla help jarule Audio, Video, and Security - Tech 5 08-29-2003 12:19 AM
head unit help please! jarule Audio, Video, and Security - Tech 3 02-22-2003 03:34 PM
