performance clutch? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-12-2006, 12:35 AM   #1 (permalink)
Im Camfuzed!?!
mzfe5speed's Avatar
iTrader Score: 6 reviews
View mzfe5speed's Photo Gallery
4th Generation performance clutch?
im planning on getting a performance clutch pretty soon, but i dont know which one to get. i have the 3.0 1mzfe, does anybody have any feedback to the clutch that they have used?
Go Camry Go!!! Was Officially BOOSTED!! And it was Awesome!!
http://www.cardomain.com/ride/2488906
My Impreza http://www.cardomain.com/ride/2876078
mzfe5speed is offline   Reply With Quote
Old 02-13-2006, 10:07 AM   #2 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
Exclamation Center Force
Center Force makes some very fine clutches which seem to take plenty of abuse.
For above averge street use (no side stepping) go with the CF1.
If you can tolerate a bit of chatter on the uphill takeoffs, go for the dual friction. They are good, just not as comfortable on a daily driver.
I am not sure what your intentions are but think of this, if you plan to really abuse a clutch, just remeber the flywheel and the PP are pointed right at the drivers seat. The point being, if it comes apart, it may take your life! So consider a billet steel FW and safety blanket. The aluminum won't stop a chunk of iron at 7000 RPM. Granted, the ods are against it making it all the way to you, but bad things do happen.
Let us know what you decide...
Randy
73sport is offline   Reply With Quote
Old 02-13-2006, 02:21 PM   #3 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Don't get a brass button. Shocking to use for the street and causes damage to the some of the components that werent meant for it. (I broke my flex pipe). Just use a standard ceramic type, with whatever brand and pressure rating you desire. As said above, apparently Centerforce make good ones. I'm using an Exedy Sports clutch at the moment.
JetspeedCamry is offline   Reply With Quote
Old 02-14-2006, 06:27 AM   #4 (permalink)
wiz
View wiz's Photo Gallery
I am getting my clutch from these guys in about a month or two. A friend of mine just put one in and it working out realy well for him. The price and power handling capacity are right on target.
http://www.dxdracingclutches.com/home.html
00 Camry LE s/c V6 5sp
Better life through CAMistry.
wiz is offline   Reply With Quote
Old 02-14-2006, 11:19 PM   #5 (permalink)
Im Camfuzed!?!
mzfe5speed's Avatar
thanks for the tips, now all i gotta do is wait for my tax return. im planning on getting the unorthodox flywheel along with the clutch, that should be a fun couple upgrades. i cant wait!
Quick Shifter or High Performance Clutch? rjwelce 1st Generation (2005-2010) 10 12-12-2005 08:02 AM
UPDATE: Clutch problem canadianae92 Archived Corolla threads 2 10-29-2005 05:13 PM
My clutch has started slipping and I dont know why REAPER STRAIN Camry & Solara Lounge 55 09-19-2005 07:47 AM
performance clutch gen 4 1mz I4 to V6 Swap 3rd & 4th Generation (1992–1996 & 1997–2001) 2 05-30-2004 10:49 PM
Performance Clutch Irishjerf Camry & Solara Lounge 2 05-31-2002 05:17 PM
