HELP! Why is my V6 LE screeching? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-14-2006, 02:21 AM   #1 (permalink)
Turn1's Avatar
View Turn1's Photo Gallery
3rd Generation HELP! Why is my V6 LE screeching?
Everytime I make a left turn, I hear a loudass screeching sound coming from the front of my car. I thought it was the brakes, so four new rotors and new pads all around went in yesterday. Took it for a test drive, and as soon as I load the front end on a left turn, SCREEEEEEEEECH! Sounds like KING KONG draggin his nails on a huge blackboard. Any thoughts are greatly appreciated.
Aloha!
998 U UP
Turn1 is offline   Reply With Quote
Old 02-14-2006, 02:25 AM   #2 (permalink)
OMNI's Avatar
View OMNI's Photo Gallery
could be the power steering pump or belt.
hoi hoi
OMNI is offline   Reply With Quote
Old 02-14-2006, 08:11 AM   #3 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
^Yeah I would check those. My car would make the same noise ,but when I turn both directions, and for mine it was the pump.
http://www.xclusive.bz
Old 02-14-2006, 01:59 PM   #4 (permalink)
View DrastikDynasty's Photo Gallery
You might need to tighten your belt......that was the problem with my car.......
DrastikDynasty is offline   Reply With Quote
Old 02-14-2006, 03:47 PM   #5 (permalink)
MCH Engineer in training
Location: A-town, Doylestown, & Northampton, PA; Morgantown, WV (WVU COE)
View ag6286's Photo Gallery
probably a belt but if it kinda carries a thud/bounciness to it in the car it could be your CV joints, check to see if the boots are torn at all, outter is more likely to go than inner
ag6286 is offline   Reply With Quote
Old 02-14-2006, 05:48 PM   #6 (permalink)
Turn1's Avatar
Thanks guys for all the replies. Timing belt, seals, gaskets, and all belts were replaced last week. I knew the power steering pump was leaking, so I bought a new one and will install that in this week. I hope it's the pump. I didn't know the pump would make a screeching sound on left turns only? I figured if it was going bad it would make a humming sound regardless if it were left or right. But with the power steering reservoir filled, and only on left turns at speed the screeching from hell appears. I dunno, my car's haunted, haha.
998 U UP
Old 02-14-2006, 06:03 PM   #7 (permalink)
Dude Wheres My Car?
nukem678's Avatar
View nukem678's Photo Gallery
Are your tires in good condition? My old car did that when i took a turn over 15 miles an hour but i had bald ass tires. Usally Only when turning left yhough!!
I lost my Camry in a parking lot once, Now it will never happen again
nukem678 is offline   Reply With Quote
Old 02-15-2006, 08:18 AM   #8 (permalink)
'93 LE Wagon, V6
View DFBonnett's Photo Gallery
If it only does it at speed and not while standing still as you turn the wheel lock to lock, my guess is wheel bearing.
DFBonnett is offline   Reply With Quote
Old 02-16-2006, 02:30 PM   #9 (permalink)
Turn1's Avatar
Wheel Bearing? Hmm...which side should I change?
998 U UP
Old 02-16-2006, 03:00 PM   #10 (permalink)
'93 LE Wagon, V6
Get a jack under it and spin each wheel in turn in both directions. Listen for sounds that shouldn't be there. Grab the tire top and bottom and wiggle, looking for noise or play. I'm not positive it's a wheel bearing so verify any diagnosis on site before you hit the parts store.
Very interesting... NH05TACOMA 2nd Generation (2005+) 52 04-08-2008 06:20 PM
SE better than LE for my new car...Comments? kthan Camry & Solara Lounge 20 09-06-2005 11:46 AM
1998 Camry LE V6 trixx Introduce Yourself Here 3 07-01-2003 01:13 AM
