Squeaky brakes drivin me crazy!!!!!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-06-2003, 12:51 AM   #1 (permalink)
View Lorinser Camry Gen3XLE's Photo Gallery
Work fine but are noisy at times. Replacing the pads with OEM ones and using a shimm kit should do the trick?
Lorinser Camry Gen3XLE is offline   Reply With Quote
Old 01-06-2003, 12:59 AM   #2 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $700265
iTrader Score: 6 reviews
View EKam's Photo Gallery
Just make sure you got the 2 v-shape springs on the pads that force them away from your rotors and you should be fine.
The shim kit includes the 2 v-shape springs.
18/6/08 - Sayonara Kamuri!
EKam is online now   Reply With Quote
Old 01-06-2003, 10:37 AM   #3 (permalink)
View Colorado's Photo Gallery
Yes OEM will make a huge difference. They are also much thicker than after market and will last a long time. As said before get the shim kit too.
Colorado is offline   Reply With Quote
Old 01-06-2003, 11:37 AM   #4 (permalink)
View rcj93cam's Photo Gallery
why dont you try to rough up the ones you have if they are still in good shape. The ones you have are probably glazed and need to be rought up, mine are the same way.
93 LE V6
rcj93cam is offline   Reply With Quote
Old 01-06-2003, 04:36 PM   #5 (permalink)
Tried that already, been having this problem. for months
Old 01-07-2003, 05:36 AM   #6 (permalink)
CaMrY 4th GeN
View fallennite's Photo Gallery
is there a way to fix this
I have the same problem with my car. I replaced the brake pads and still the noise is there. i know it hasto do with my brake because it gets louder when i hit them and then quiets down
fallennite is offline   Reply With Quote
Old 01-07-2003, 08:09 PM   #7 (permalink)
took it to the mechanic today, eneded up being the rear brakes not the front ones and they were totally shot. replaced it and got a shim kit. problem solved, noise is gone. thanx for ya help nonetheless.
Old 01-21-2003, 09:17 AM   #8 (permalink)
Current title:
View Ikon's Photo Gallery
Rotor Regrind Time
I do my own brakes whenever the pads are worn, however every so often you need to take your car into some shop, pref. not the dealer and get your rotors run or "regrind"-ed. A little bit of high-temp grease on the clips that hold the pads in place, a spray of brake cleaner and should be good to go. Keeping all necessary parts is a must, i.e. shims, springs, clips, etc.
Ikon is offline   Reply With Quote
