99 LE - IGN wire in left kick panel - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-14-2006, 07:07 PM   #1 (permalink)
View sixto's Photo Gallery
I'm installing an auto-dimming rearview mirror. I have the wires down to the left kick panel. There's a ground point, so that part is done. I have a Haynes manual which isn't very useful in identifying a wire in that location that's live when the key is in the ON position. Can someone help me find such a wire in that location? Otherwise I'll run the wire to the key switch.
Thanks,
Sixto
99 LE 4-cyl
sixto is offline   Reply With Quote
Old 02-15-2006, 04:46 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Black/yellow wire at the ignition harness.
Ignition harness is at the bottom of the steering column. Big fat wires, you can't miss them.
"Skoolin' the unlearned!"
Old 02-15-2006, 03:55 PM   #3 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $280492
View csaxon's Photo Gallery
http://www.geocities.com/brandsport4/
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 02-15-2006, 09:19 PM   #4 (permalink)
Thanks for the link. My mirror came with instructions. What I don't have is a manual with pin out description of the dozen connectors behind the kick panel. There must be an IGN wire in that jungle. Worst case I'll route it to the key switch.
Sixto
99 LE 4-cyl
Old 02-16-2006, 03:40 PM   #5 (permalink)
For future reference, IGN power is available in the junction block around the left dash fuses:
- connector 1T (9-pin connector which is third in going forward from the door jamb along the bottom) black wire with red stripe in position 8. Downstream of 5A IGN fuse.
- connector 1J (13-pin connector which is in the upper door jamb corner on the back side of the junction block) red wire with blue stripe in position 2. Downstream of 10A GAUGE fuse.
Pin-outs are different for 6-cyl so do your research!
Sixto
99 LE 4-cyl
MSD Ignition luisitol Camry & Solara Lounge 23 03-15-2009 02:13 PM
Basic Amp Install Instructions Phi Audio, Video, and Security - Tech 11 04-06-2005 02:25 PM
extra battery 97avalonxls Audio, Video, and Security - Tech 9 09-20-2004 12:09 PM
Subwoofer Install? CamrySpeaksJL Audio, Video, and Security - Tech 17 02-07-2003 08:33 AM
