Hiding switches - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-14-2006, 09:49 PM   #1 (permalink)
Iron Chef IV
View drunken_panda's Photo Gallery
Gen5 Hiding switches
I have about 4 switches to hide, they are the size of the power switch on the power supply on the power supply of computers. I want to hide them from sight. I was thinking about the center arm rest, but then I worry about things in there sliding around switching things on or off. I was also thinking about the glove box, but then I couldnt take the box out to replace the filter behind it. I was also thinking about just to the left of the drivers leg, but there isnt enough room in there. ANy other suggestions?
drunken_panda is offline   Reply With Quote
Old 02-14-2006, 09:55 PM   #2 (permalink)
*INSERT WITTY TITLE HERE*
View BlueCam's Photo Gallery
just out of curiosity, what are the switches for?
BlueCam is offline   Reply With Quote
Old 02-14-2006, 09:57 PM   #3 (permalink)
View sajnaj's Photo Gallery
if u get rocker swithes and some double sided tape stick them under urseat
sajnaj is offline   Reply With Quote
Old 02-14-2006, 09:57 PM   #4 (permalink)
my name isn't really Bob
View Fresco Bob's Photo Gallery
If you are hardcore with wiring and you wanna go ultra stealth, you could take existing buttons on your dash (radio, hvac ect) and wire em up for whatever your switches enable now. Otherwise the armrest would be your best place, but just build some guards around them so nothing will hit them.
Fresco Bob is offline   Reply With Quote
Old 02-14-2006, 10:10 PM   #5 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $397185
View RningOnFumes's Photo Gallery
hmm...what bob said.
.....the place where the plastic covers the under side of the steering column
.....inside the little covered storage compartment (where people keep disc jackets)
.....up where you keep the sunglasses
.....upsidedown where your clock is
.....right alon where you right leg would touch the center console
.....right underneath the dash--along the parts not part of the steering column...
..want more?
i'm assuming since you are hiding them, you'll know what use each is for and so will memorize what each is for....i have a few hiddent switches too.
edit.... muhaha....
..... along underneath any part of your fabric where you can just feel the buttons, but you can't see them at all
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is online now   Reply With Quote
Old 02-14-2006, 10:16 PM   #6 (permalink)
Hawkeye-SE's Avatar
View Hawkeye-SE's Photo Gallery
I like this idea. Especially if you can recess them in.
Hawkeye-SE is offline   Reply With Quote
Old 02-14-2006, 10:38 PM   #7 (permalink)
Iron Chef IV
I like the sun glass place, but that means taking apart the headliner to run the wires, a little too much work for me. These switches are about an inch tall and mount in a hole .5 by .25 inches, so the clock isnt feasable. I am thinking about the top tier of the center armrest
These switched are for lighting and power. I am taking those power inverters and hard wiring them in so that there is a normal 3 prong outlet in the dash. This will be direct wire to the battery so I need a switch to prevent the battery from draining down.
Old 02-14-2006, 11:08 PM   #8 (permalink)
Dominican Republic
Dj-torn's Avatar
View Dj-torn's Photo Gallery
Check out where i put the switch for my neons
http://gallery.caraudio.com/vg/showi...mageuser=12813
Stock 2002 Camry LE: 2AZ-FE: VVT-i
Dj-torn is offline   Reply With Quote
Old 02-14-2006, 11:39 PM   #9 (permalink)
Iron Chef IV
^ thats where I was going to orginally put them, but I am saving thatspace to put all the connections for my USB, card reader, Audio and Video.
Old 02-14-2006, 11:41 PM   #10 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
I put a push button switch under the handle to the coin drawer, to the left of the steering wheel in my Gen5 before. You would put your hand on the drawer as if opening it and press the button with your index finger to operate it.
I had a push button momentary switch, but you can get push button on-off switches also.
I taped the wire to the under side of the drawer and cut away some plastic on the dash so the wire had clearance.
2007 Camry 2.4L 5M
Old 02-15-2006, 12:58 AM   #11 (permalink)
Sebastian Loebs evil twin
BakaWill's Avatar
View BakaWill's Photo Gallery
just outta curiosity why hide the swicthes?
1990 camry dx 3s-fe
BakaWill is offline   Reply With Quote
Old 02-15-2006, 01:55 AM   #12 (permalink)
Iron Chef IV
I want everything to look clean and stock. If there are switches and plugs everywhere it would make it look tacky and ricey.
I was thinking of filling in the coin tray with switches, but it is too small.
Old 02-15-2006, 08:18 AM   #13 (permalink)
Dude Wheres My Car?
nukem678's Avatar
View nukem678's Photo Gallery
If you go to pep boys they sell a kit for like 20 bucks that is a flat fanel switch for 4 things.Its really small like the switch for my reverse gauges. Id go to pep boys and check it out if you got one near.
Its really cool and i think their adjustable from momentary to constant.
I lost my Camry in a parking lot once, Now it will never happen again
nukem678 is offline   Reply With Quote
Old 02-15-2006, 09:52 AM   #14 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Get smaller switches.
I like miniature toggle switches, their small enough to stash pretty much anywhere.
"Skoolin' the unlearned!"
Old 02-15-2006, 12:20 PM   #15 (permalink)
View elhsgrad04's Photo Gallery
i am putting mine under the e-brake i cant put them in the place beside power outlet cause my lili is molded there...
elhsgrad04 is offline   Reply With Quote
Tacoma Rocker Switches KyRick 2nd Generation (2005+) 32 10-08-2006 10:37 PM
How many switches? protoyota Tercel, Paseo, Starlet, and Sera Forum 1 08-19-2005 05:09 PM
Factory switches flghtrn 2nd Generation (2005+) 12 07-26-2005 06:15 PM
