changing the 100 amp fuse - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-15-2006, 01:42 PM   #1 (permalink)
View golfingdan's Photo Gallery
Angry changing the 100 amp fuse
Hi
I am new here and I have a 98 4cyl camry with a blown 100amp fuse. I know that it bolts in at the bottom. The problem is How do I get at the bolts to get the fuse out. Dump question I know but I must be doing something wrong because I am not able to get at them.
Help Dan
golfingdan is offline   Reply With Quote
Old 02-15-2006, 02:33 PM   #2 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Are you talking about the fuses on the battery terminal? If so, they should just pull out.
JetspeedCamry is offline   Reply With Quote
Old 02-15-2006, 03:40 PM   #3 (permalink)
100 amp fuse
yes they are behind the battery terminal but on the 100 amper it has two legs on it that have a hole in each that two screws go in at the bottom of it to hold i it so you can't pull it out. problem is I can't figure out how to get at the screws. The screws are down in the box
HOW TO: 2005-06 Fog Light Modification SWTRDSPORT 2nd Generation (2005+) 110 10-24-2011 07:40 AM
05 tacoma fuse problem DudeGuy 2nd Generation (2005+) 1 08-23-2005 11:54 PM
Setting up an active system. The basics cam2Xrunner Audio, Video, and Security - Tech 4 07-21-2005 03:04 PM
Fuse near battery JohnCWms27 Audio, Video, and Security - Tech 9 11-30-2004 06:16 PM
Question about fuse BEI Audio, Video, and Security - Tech 5 11-12-2004 08:54 AM
